Thread: Overcooling - Thermostat or Fan fault?
Results 1 to 10 of 12
  1. Overcooling - Thermostat or Fan fault?
    Hi, I hope you can help. Just purchased 1.8se and trying to iron out a few teething problems!
    When driving, the car hardly heats up at all (temp gauge about 65), same with oil temp. The gauge is ok as it goes up a bit if the car idles for a while.
    I reckon the thermostat is stuck open but I'm not sure how the viscous fan is meant to operate. It runs all the time. Most viscous fans I've seen on other cars do this but the Haynes manual seems to suggest it shouldn't turn at all until about 80 degrees???
    (The electric fan does not run all the time.)
    Thanks in advance for any advice, Ian
  2. Re: Overcooling - Thermostat or Fan fault?
    Sep 2007
    yorkshire
    Quote Originally Posted by pologt View Post
    The viscous always spins! You are correct about 80 degrees, This is when the viscous internals tighten up to make it spin more faster.
    What do your heaters blow like?
    2003 AUDI AVANT SPORT TDI
  3. Re: Overcooling - Thermostat or Fan fault?
    It's hard to tell with the heater as the climate control works its wonders but I must say the 'blast' from the vents isn't the warmest I've ever had in a car.
    Heat comes out reasonably quickly from cold though.
    If the fan is operating correctly then, I think it must be the thermostat. That's ok... cheaper than a fan I imagine.
    Many thanks, Ian
  4. Re: Overcooling - Thermostat or Fan fault?
    Sep 2007
    yorkshire
    MMMM, Thermostat sounds ok to me.
    Maybe your heater matrix is a little clogged and not letting the correct heat off!
  5. Re: Overcooling - Thermostat or Fan fault?
    I'd say the heating is adequate but not brilliant.The main symptom though is the engine being too cold. I think if the matrix was blocked it would make it hotter not cooler???
  6. Re: Overcooling - Thermostat or Fan fault?
    Sep 2007
    yorkshire
    What I mean is when the antifeeze and like is not changed when it should be. It leaves a coating on the matrix (not blocked in a sense) but stops the matrix from letting the correct heat off.
    This is a well known fault in which folk have had there matrix changed. on all cars, not just yours!
  7. Re: Overcooling - Thermostat or Fan fault?
    Thanks for your help. I'll change the thermostat and flush the cooling system.
  8. Re: Overcooling - Thermostat or Fan fault?
    Sep 2007
    yorkshire
    Yes change the thermostat, I wasn't thinking on the last comment.
  9. Re: Overcooling - Thermostat or Fan fault?
    Hi, just a quick update incase anyone else is experiencing a similar problem.
    I finally got round to changing the thermostat and my temp gauge reaches the centre fairly quickly now.
    It's worth trying if you have similar problems, it only cost about £12 from Audi (remember to get a new rubber seal).
    Good luck!
  10. Re: Overcooling - Thermostat or Fan fault?
    Jul 2007
    somerset
    8 Post(s)
    Just a note to add, i also had same problems with the temp gauge not working, mine was also the thermostat (£5 from AVS) your car should have the pink/red G12+ coolant, don't ever mix this with other coolants as it will react and ruin your cooling/engine. The idea of the G12+ is that it is long life and hence should never need changing, except where the coolant has been topped up with water and diluted the ratio. I would not expect a heater matrix to block up under normal circumstances.
  1. thermostat
    By charles0106 in forum 80 - 90
    Last Post: 19-11-2007, 11:43 AM
  2. Where's my thermostat?
    By AMK in forum Audi A3 - Archive Topics
    Last Post: 03-04-2007, 11:22 PM
  3. A3 1.8T Thermostat
    By JonFrancis in forum Audi A3 - Archive Topics
    Last Post: 02-01-2007, 12:30 PM
  4. thermostat
    By salty in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-10-2006, 07:53 PM
  5. T4 thermostat
    By dolphinfreindly in forum The Classic VW's
    Last Post: 10-05-2006, 10:32 PM
