Thread: Overcooling - Thermostat or Fan fault?
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Overcooling - Thermostat or Fan fault?
    Hi, I'm having the same problem with my temp gauge. Can anybody tell me where the thermstat is located ? (1.8 se Avant)
  2. Re: Overcooling - Thermostat or Fan fault?
    That's the same model as mine. You need to remove the engine undertray and tackle it from below... I used ramps.
    It is near the front on the left (nearside).
    The bolts are a little tricky... I needed a really slim socket for one and had to loosen some kind of stabiliser bar that was in the way of the other.
    Use some grease on the new rubber seal to hold it in place when you are replacing the thermostat cover.
    When refilling the anti-freeze, half pull off the rubber heater hose (near bulkhead) until the small hole in the tube is past the stub. This allows the air to bleed out of the heater matrix. (Remember to push it back on when done!)
    Good luck.
  1. thermostat
    By charles0106 in forum 80 - 90
    Last Post: 19-11-2007, 11:43 AM
  2. Where's my thermostat?
    By AMK in forum Audi A3 - Archive Topics
    Last Post: 03-04-2007, 11:22 PM
  3. A3 1.8T Thermostat
    By JonFrancis in forum Audi A3 - Archive Topics
    Last Post: 02-01-2007, 12:30 PM
  4. thermostat
    By salty in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-10-2006, 07:53 PM
  5. T4 thermostat
    By dolphinfreindly in forum The Classic VW's
    Last Post: 10-05-2006, 10:32 PM
free web
stats
