Thread: noisy start up on 1.8t 20v sport
Results 1 to 10 of 10
  1. noisy start up on 1.8t 20v sport
    Oct 2006
    My 200 1.8t 20v sport passat estate makes a horrible noise on startup for a few seconds,it sounds almost like a pump going too fast with nothing in it,it also makes a nasty fast loud ticking noise at tick over but as soon as you get the revs up a bit it goes??the noise appears to be coming from the topend but is not half engine speed but quite fast.any ideas?
    Cheers Ray
  2. Check oil pressure
    Oct 2006
    Hi, Check Oil pressure readings cold and Hot. Could poss. be worn Oil pump? What mileage has vehicle done? Manual or Auto? Has oil and filter been changed recently? Is noise louder from top of cam cover towards bulkhead?
    Oct 2006
    Hi golfer7, its a auto with 135k on the clock,the noise appears to come from the raised bit of the cam cover over the cam chain,we have only done 100ish miles since getting it,when i`m back at home i`ll put a orig` oil filter and some new oil in it.
    i think there may be low oil pressure at tickover-how hard is a oil pump change?
    What oil should i use?
    Cheers ray
  4. Noisy Engine
    Oct 2006
    Hi Ray, I'd advise Castrol Magnatec semi-synthetic oil.To replace the oil pump it's a real work up! Big job i.e. dropping subframe to get the sump off. Genuine oil pump I think is about £100 ish plus gaskets/sealer.
    My advice is change oil & filter and get oil pressure checked.
    V.W. will have fiquires what pressure you should have at idle & at revs when vehicle hot...
    Good luck Golfer7
    Oct 2006
    Thanks, i`ll do the oil first then i`ll update. Ray
    Oct 2006
    Quote Originally Posted by ssray View Post
    Cheers Ray
    A few possibilities come to mind, Ray:
    1) cam chain tensioner and/or cam seals, particularly should the noise return on hot idle;
    2) secondary air pump, assuming you have those in the U.K. The combination valve at the back of the cylinder head activates the pump for about 20 seconds following a cold start.
    Best, John E.
    Oct 2006
    Thanks john, iyts going to have to go into a garage as i dont have any spare time at the mo`.
    cheers Ray
  8. Question noisy start up on 1.8t 20v sport
    Nov 2006
    Yes, it sounds like I have the same issue.
    I hear a noise coming from around the engine (camshaft adjuster unit) when I start my 1.8T
    However when I press the gas the engine noise disappears!!
    Oil pressure is fine (no warning lights), the noise only appears when I start the car otherwise everything good. Secondary air pump is good, no problems.
    Should I replace camshaft adjuster unit ($$$) or wot else should I check?
    Wot was the solution Ray ?
    Oct 2006
    give me a chance-no solution as yet-we have a baby on the way and a house that needs finishing before i am allowed to play(sorry fix) the vw.
    i may give up and send it to a garage.
    Ray
    Oct 2006
    Sorted-it told me to service now,so i did, also passed its mot,first car we have had that went through first time.
    the noise is now gone i think the oil was knackered and the fresh stuff has fixed it.
    now how do i sort out the bloody air blower/air con?
    Cheers Ray
    glad it wasnt the cca-phew!
  1. A4 1.8 1996 noisy cold start
    By PK1 in forum New Member Introductions
    Last Post: 26-03-2009, 09:37 AM
  2. 2000 1.8t sport-would not start
    By ssray in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2007, 11:57 AM
  3. Noisy air con
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2007, 04:54 PM
  4. Noisy AC
    By andywell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2007, 06:15 PM
