Thread: Audi a4 b5 1.6 N0 4 cyl misfire?
  1. Audi a4 b5 1.6 N0 4 cyl misfire?
    Hi all, this is my first post and I hope some expects among can help. My car suddenly developed a misfire as in no firing on no4cyl at all, here are the things I've checked so far.....
    Good spark at lead......
    Swapped spark plug...
    Swapped injector...
    Compression test..11.7bar...
    Measured injector resistance..within limits 14-17ohms....Measured voltage output from ECU pin 65, 12.4v briefly then 0v, same at injector end....Checked continuity of wire from pin 65 ecu to injector tis ok.....Checked feed voltage to injector from fuel pump relay, Ok.........................
    Still not firing on No4 cyl, I hope i've missed something...any ideas before I submit to a dealer. thx in anticipation
  2. Re: Audi a4 b5 1.6 N0 4 cyl misfire?
    108 Post(s)
    1816 Post(s)
    Well with good compression, spark and fuel I would ay the injector isn't being driven from the ECU. You need an oscilloscope to check this or drive it in Output Tests in VAG-COM. The other possibility is a chronic air leak on that cylinder.
  3. Re: Audi a4 b5 1.6 N0 4 cyl misfire?
    Hi crasher, thx for the quick reply/ideas, I'm waiting for a pc cable to use vagcom, I'll check for air leaks tommorrow, hope I sort it son already cost me a day off work.....cheers I'll let you know if I sort it.
  4. Re: Audi a4 b5 1.6 N0 4 cyl misfire?
    Hi, Problem sorted, thanks for your help........
    I found a corroded pin in the plug to distributor, I think it is ign amplifier, anyway cleaned it up reconnected and I now have a four cyl engine again, thx.....
  1. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  2. 1994 Audi 80 TDi misfire
    By MadMalx in forum 80 - 90
    Last Post: 08-01-2008, 01:17 AM
  3. 99 Audi A4 Quattro, Misfire Cyl 3, Help!?!
    By wilvelas in forum Audi A4 - Archive Topics
    Last Post: 03-12-2007, 10:41 PM
  4. mk3 gti 16v misfire
    By frenchie in forum Golf MK3 - 1993 - 1999
    Last Post: 26-10-2007, 08:07 PM
  5. Audi 80 Avant - Intermittant misfire ?
    By kbowern in forum 80 - 90
    Last Post: 23-05-2007, 01:50 PM
