Thread: Driver Information System fault?
  1. Exclamation Driver Information System fault?
    On my 2001 A6 2.4 V6 the front brake pads worn symbol is continually lit up on the DIS.
    I checked the brake pads myself back in November 2007 and compared them to some new pads I already had in case they needed replacing. There was plenty of life left in them, I would suggest not even half worn. I am satisfied that there is no need to replace them.
    The light came on during a particuarly cold snap, and the freezing weather has played mischief before with the electrics at times.
    I will check the pads myself again, if they need replacing of course I will replace but if they are no where near the wire to complete the circuit then I will not replace or is it not as simple as that?
    If they are (or are not) to be replaced how do I re-set the DIS?
    Many thanks
    M
  2. Re: Driver Information System fault?
    May 2007
    For brakes the DIS automatically resets when it does not see the fault.
    If you have the yellow brake pad wear symbol on then this is either pad wear - approx less than 4mm, or a break in the circuit. Possible a bad connection where the pads plug in.
    If you have the red brake pad wear symbol this is fluid level, though mine comes on after heavy rain, or frost. Not sure where the water ingress is, as no sign of water in the car and the famous drain hole under the battery is clear !
  3. Re: Driver Information System fault?
    It is the yellow symbol. I'll check the pads again at the weekend.
    Thankyou for your earlier email.
  4. Re: Driver Information System fault?
    Check the wire - mine broke and the symbol really started to annoy me....
  5. Re: Driver Information System fault?
    Jul 2007
    Cheshire, or my A6
    Just in agreement with Niall, often the ABS wires get caught up or corroded. Just check they are not wrapped round any of the brake/suspension systems and check the wire isn't corroded as far as you can see.
    Paul
  6. Re: Driver Information System fault?
    Jul 2008
    Lisburn
    15 Post(s)
    i have this same fault - the rears were thin about 4mm so changed these but no sensor wires- guessing wear is detected through the EPB? fronts are approx 10mm changed them last year and can touch pad material without squeezing my finger...
    I used OBDeleven app open close and test function is there a specific function to reset the lights for rear pads?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  7. Re: Driver Information System fault?
    Jul 2013
    76 Post(s)
    Check the wiring at the sensor plugs as they tend to snap there.
    Dan
    2009/2010 2.0 TDIe SE
  1. Driver Information System screen blank
    By stu.gtx in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-07-2008, 10:47 PM
  2. Driver Information Screen Blank
    By Rojosa in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-12-2007, 11:28 AM
  3. Driver Information Display
    By JPMCT in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-11-2007, 09:25 AM
  4. Driver Information System not working - A6
    By stu.gtx in forum Archive posts
    Last Post: 13-11-2007, 02:28 PM
  5. Electronic Service Information System
    By wid77 in forum Archive posts
    Last Post: 06-11-2007, 11:02 PM
