Thread: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
  1. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    hi to make the message short as possible .the car was losing power to start with when driving it , when you put your foot down it was hesitant to go over 70 mile an hour and for some reason for a few minutes it would regain full power as if nothing was wrong and then it would go back to losing power again . its been like this for some months now .an till yesterday i was reversing off the drive and for some reason the car stopped as if the timing belt had snapped it was that sort of feeling .
    the fault list that i have done to try and pin point because it will not start no more
    the timing belt was done last year by vw done a check on the teeth to see if the belt had jump a tooth ,it seems ok no damage to be seen here .
    i took the solenoid out to test it using a 12volt battery to test the inwards plunger and out wards plunger this also seams ok no fault ...
    the mass air flow MAF sensor .i can't check this ..
    i have undone the injectors to see if fuel is getting through and the fuel pump seams to be working
    the car will turn over off the key ok but won't start .and
    before trying to start it off the key i get the glow plug light comes on and goes off as normal but when turning over the engine i get some smoke and a strong smell of diesel come out of the exhaust .
    can any one help me locate and try and find out what is causing this problem ,
    or has any one else had this sort of problem with passat 1996 .PS i this its a 1z engine in mine
    any help with thanks
    jill
  2. Re: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    1837 Post(s)
    Well first of all you should get a fault code read done. Try spraying a little Easy Start into the intake to see if it fires up. If it does and there are no relevant fault codes, my money would be on the injection pump having skipped a tooth, it is quite common.
  3. Wink Re: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    hi thanks its a diesel not petrol
  4. Re: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    Sep 2007
    yorkshire
    Quote Originally Posted by kezia View Post
    Easy start works on both.
    2003 AUDI AVANT SPORT TDI
  5. Re: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    1837 Post(s)
    I know it’s a diesel, a TDI unlike the Dti you called it, VAG petrol engines don’t have cam belt driven injection pumps that is why I said spray Easy Start into the intake which is traditionally used to kick recalcitrant diesels into life, I have never used it on a petrol engine.
  6. Re: Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    Sep 2007
    yorkshire
    I wonder if it is a VW and not a renault.
  1. 1996 Passat 2.0 idle problem
    By dubdaze in forum Early Passat Forum - Pre 97
    Last Post: 09-04-2009, 11:25 AM
  2. A4 1.8 1996 noisy cold start
    By PK1 in forum New Member Introductions
    Last Post: 26-03-2009, 09:37 AM
  3. B4 (1996) Passat central locking
    By BiggerEars in forum Early Passat Forum - Pre 97
    Last Post: 21-01-2008, 11:56 PM
  4. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    By kezia in forum Early Passat Forum - Pre 97
    Last Post: 06-01-2008, 08:08 PM
  5. Help! 1996 A4 won't start need ideas
    By ninthtoe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2007, 10:58 PM
