Thread: low beams wont turn on
  1. low beams wont turn on
    Dec 2007
    i got off work the other night to fint that as i disengaged the parking brake my lights wouldn't come on. the high beams still work, and ive been driving with these on the last two nights. i checked the fuses and they look like they are fine.
    oh yea, 2001 mkIV golf 2.0 manual transmission.......ANY IDEAS?
    please any feed back would be helpful
  2. Re: low beams wont turn on
    1841 Post(s)
    How about two blown bulbs, I have seen that a few times.
  3. Re: low beams wont turn on
    Dec 2007
    ok, wierd. i replaced one of the bulbs with an old one i had and it worked....same with the other.....why would both lights just blow?
    I recently put in some Silver star Ultra lights, probably three months ago. there is no moisture or cracks in the light housing.....any ideas on what else i shouls check?
  4. Re: low beams wont turn on
    1841 Post(s)
    Thought that would be the problem, these silly bulbs. They are rubbish and prone to blowing. You should check your alternator for a steady output but I suggest buying top quality make bulbs, those were probably made in China.
  5. Re: low beams wont turn on
    Dec 2007
    they were made in germany, and they were the highest quality ones i could find.....i talked to the clerk and he said he hasn't heard any complaints about them so im guessing its an electrical problem......alternator you say? could it be anything to do with the fact that they are day running lights (or whatever the technical term is), and they are over used for nothing? i would think that would blow them quicker? maybe not? im a newbie to these tricksy ********
  6. Re: low beams wont turn on
    1841 Post(s)
    Language Timothy!
    Anyway, it would be a good idea to have the alternator output tested for voltage spikes.
  1. VW passat W8 fan wont turn off
    By LoveMyDUB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2007, 06:58 PM
  2. Disable Fog switching when full beams are on
    By Stu_c in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2007, 12:27 PM
  3. wont turn over
    By kesn in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2007, 09:04 PM
  4. No main beams?
    By WJI8985 in forum 80 - 90
    Last Post: 01-07-2007, 06:52 PM
  5. Cant turn the heat off.
    By ferrispedro in forum Touran - Sharan - Caravelle
    Last Post: 29-06-2007, 02:30 PM
