Thread: Diagnostic connector on 96 Passat TD L
  1. Diagnostic connector on 96 Passat TD L
    OK, I feel really dumb asking this one. I got my old Passat TD L Umwelt (AAZ) back from garage with replacement engine fitted just before Christmas. I got a VAG-Com cable for work on my Sharan but would like to do a check on the Passat. After a lot of poking around both on the car and in these forums I still cannot find the diagnostic connector socket! Is there one?
    Cheers, OD
  2. Re: Diagnostic connector on 96 Passat TD L
    Dec 2007
    I have a '95 estate, the diagnostic is to the right of the radio and the cover looks like it is a 1'' speaker or sensor or something, just above the steering wheel adjuster. It just clips out and in.
  3. Re: Diagnostic connector on 96 Passat TD L
    Thanks for that - I'll look in the ...Next Year :-) Cheers, OD.
    Yup - it's there - thanks and a Happy New Year :-)
  4. Re: Diagnostic connector on 96 Passat TD L
    Hi - can you remember where the connector interface was located on your old Sharan?
  5. Re: Diagnostic connector on 96 Passat TD L
    1841 Post(s)
    Pull the ash tray insert out.
  6. Re: Diagnostic connector on 96 Passat TD L
    "Pull the ash tray insert out." - and for the avoidance of doubt, it's the one between the driver and passenger footwells :-) OD
  1. Where is Diagnostic Socket on Passat B6?
    By pl4tonas in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-06-2007, 08:35 PM
  2. location of VAG-COM connector
    By guy1 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-05-2007, 12:45 PM
  3. OBD connector
    By Audifan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2007, 05:18 PM
  4. Vag-com mk3 connector
    By Kev2904 in forum VCDS - General Questions
    Last Post: 16-03-2007, 09:07 PM
  5. OBDII connector in Passat 2003...
    By anoak in forum Passat - Archive Topics
    Last Post: 09-07-2006, 07:36 PM
