Thread: MK4 Golf TDI starts from cold with temp sender disconnected
Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
  1. MK4 Golf TDI starts from cold with temp sender disconnected
    Aug 2007
    I have a MK4 golf TDI (110bhp) on a 1998 plate that has problems starting from cold but not when warm. Glow plugs and battery are new.
    When cold the glow plug symbol on the dash goes out just as quickly as when it is warm and the car struggles to start. However if I disconnect the coolant temperature sender the symbol stays lit for some time. When it finally goes out the car starts absolutely fine.
    I assumed therefore that the coolant temperature sender is not working and bought a replacement. This has not rectified the problem and the car starts first time in the cold only when the sender is disconnected.
    Does anyone have any ideas on what is causing this problem?
    Many thanks in advance!
  2. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    May 2007
    Quote Originally Posted by peteheat View Post
    i had the same problem, and i sprayed contact cleaner into the water temp sender plug as two pins looked rusty. it worked a treat.
  3. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    135 Post(s)
    2026 Post(s)
    If you have a fault code read done you will find you have a faulty coolant temp sender code stored. Have this code deleted and see if this helps.
  4. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    Sep 2007
    Bath, England
    Wouldn't mind checking for rust with mine also. sometimes when cold it can struggle a little. Where abouts is the water temp sender plug? And, is it easy enough to just remove and plug back in?
    Alex
  5. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    May 2007
    Quote Originally Posted by Alex Himself View Post
    Alex
    well i have an AHF engine in mine and it's at the right hand rear of the engine. (blue 4 pin plug in thermo housing). you just need to hold two clips on the plug and remove. easy to put back on too. mine was shait at starting when cold. took 3 or 4 turns. but since i done that with the plug it starts first turn when hot or cold.
  6. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    Sep 2007
    Bath, England
    Andy,
    Many thanks for the reply
    Alex
  7. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    Sep 2007
    Bath, England
    Had a quick look at this on mine and can't see a blue 4 pin plug. Should I be able to see this without removing anything?
    Alex
  8. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    May 2007
    Alex
    yes its visible without taking anything off. unless you have a different engine type, but mine is an AHF.
  9. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    135 Post(s)
    2026 Post(s)
    Alex, what year and engine is your car?
  10. Re: MK4 Golf TDI starts from cold with temp sender disconnected
    Sep 2007
    Bath, England
    Bora TDI 110bhp 1999
  1. Cold Morning Starts
    By Stevebt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2007, 11:43 PM
  2. Temp sender.
    By Woz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2007, 02:40 PM
  3. 2002 golf gti turbo cold poor starts!
    By givememorepower in forum Archive posts
    Last Post: 09-07-2007, 01:58 PM
  4. water temp sender
    By taff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-12-2006, 09:34 AM
  5. 110 BHP TEMP SENDER
    By belle2uk in forum Passat - Archive Topics
    Last Post: 23-08-2006, 12:26 AM
