Thread: 80 2.6 clutch slave cylinder
  1. 80 2.6 clutch slave cylinder
    Muir of Ord
    Hi All
    Hope you all had a good xmas, much to drink & eat etc
    Can anybody help on the location of the clutch slave cylinder on an Audi 80 2.6 V6, I can see the pipe from the brake master disapearing down the bulkhead past the steering rack & unable to see anything on the bellhousing from underneath the car (very limited on access with this engine).
    Also would anybody have a part number for the slave cylinder?
    Many thanx
    John
  2. Re: 80 2.6 clutch slave cylinder
    1840 Post(s)
    Right on top of the box, a complete swine to get out.
  3. Re: 80 2.6 clutch slave cylinder
    Muir of Ord
    Thanx crasher,
    May as well pull the gearbox out & deal with the clutch as well as its now on 150k & biting at the very top of pedal travel, then I might just be able to get at the fuel lines, as they need replacing (had a temp job to stop leaks for now) & will do in nylon/plastic.
    Without you guys where would we all be !!!!
    Many thanx
    John
  1. Clutch Master Cylinder Keeps Going?
    By NOGGA in forum Bora - 1998 - 2005
    Last Post: 22-09-2007, 09:02 PM
  2. Clutch slave problem?
    By kerrymarkp in forum 80 - 90
    Last Post: 30-05-2007, 01:22 PM
  3. A4 1.9TDI clutch master to slave cylinder pipe
    By optimobi in forum Audi A4 - Archive Topics
    Last Post: 23-02-2007, 04:30 PM
  4. 2003 S3 - clutch master/slave cylinder advice
    By S3 Owner in forum Audi A3 - Archive Topics
    Last Post: 12-01-2007, 03:50 PM
  5. Clutch slave cylinder
    By nik in forum 80 - 90
    Last Post: 08-01-2007, 11:13 AM
