Thread: abs light has come on, due to this mot has failed
  1. abs light has come on, due to this mot has failed
    Dec 2006
    my abs light has come on, only after fitting a new set of brakes, so i dont know if this is due to the new brakes or just coincedental. Does anyone know how to check with a handheld scanner or machine that i can buy, as the local garages want £50 just to check, which i think is a rip off.
  2. Re: abs light has come on, due to this mot has failed
    Hi There is a possibilaty thet you have disturbed the wiring or connectors for the abs sensors,check these,but you are going to need dignose equipent to erase the fault anyway.
  3. Re: abs light has come on, due to this mot has failed
    May 2007
    Quote Originally Posted by avantiblue View Post
    vag-
    com freeware version will check this fault and enable you to check which wheel sensor is faulty.
    My lead was £15 of ebay
  4. Re: abs light has come on, due to this mot has failed
    Apr 2007
    Tyne and Wear
    hI
    sOUNDS LIKE ONE OF THE WIRES HAS BEEN DISTURBED TO ME TOO. i'D CHECK THE CONNECTIONS FROM THE BRAKE WEAR SENSOR IF YOUR SAYING THE BRAKES HAVE JUST BEEN DONE.
    tHE WIRING LOOM FOR YOUR abs IS ALL PART OF THAT SAME LOOM.
    i'VE JUST REPLACED THE ABS SENSOR ON MINE, LIGHT WAS ON, REPLACED SENSOR , PROB TOOK ABOUT 20-30MINS AT MOST, LIGHT NOW GONE OUT.
    £25 QUID DELIVERED FOR O.E. ITEM FROM EBAY
    STEVE
  5. where can i buy the vag-com lead from to check fault
    Dec 2006
    where can i buy the vag-com lead to check faults?
  6. Re: where can i buy the vag-com lead from to check fault
    drop me a pm or email and i'll sort you out.... if you get a wriggle on, you could well have it for xmas
  1. V6 TDi Injector Pump Failed.. Now What?
    By EdF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2008, 11:13 AM
  2. Brakes on B7 RS4 failed..
    By 07AudiRS4quattr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-12-2007, 02:05 PM
  3. 93 Golf3 GTI 8v. Failed emisions.
    By paddyperv1 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2007, 11:19 PM
  4. 92 Golf Mk3 - Failed MOT - High CO2
    By Boonestone8 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-07-2007, 05:08 PM
  5. Arghhh Failed MOT
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-06-2007, 01:09 PM
