Thread: oil level sensor
  1. oil level sensor
    East Yorkshire
    orange oil light came on today with message check oil level i have checked oil level and .it only needed a bit to take it to max level now problem is light is still on so an now thinkin that sensor must be faulty anyone know where it is and how to check it
    Regards
  2. Re: oil level sensor
    Jul 2007
    Rochdale UK
    Same thing happened to me a couple of weeks ago. I took it to a VW specialist to check that it hadn't logged any errors which it hadn't.
    The Oil level sensor on a Diesel is mounted on the bottom of the sump on the opposite side of the sump from the drain plug.
    I have changed the sensor today cost me £60 from VW and unfortunatly no joy the orange oil light and the message Check Oil Level still appears.
    Any ideas greatluy received. I have heard of dash boards that need caliberating who could do this might it solve the problem.
    Cheers Ben
  3. Re: oil level sensor
    Hi With the ignition off, remove one off the battery terminals for 1 minute, see if it helps.
  4. Re: oil level sensor
    Jul 2007
    Rochdale UK
    Disconnected battery for 1 minute. Problem seems to be solved. I will take it for a test drive in a bit and check it doesn't come back on.
    Thanks very much for the advise much appreciated.
    Ben.
  5. Re: oil level sensor
    Sep 2008
    Quote Originally Posted by bg158a View Post
    Cheers Ben
    Ben try disconnecting from battery 30 secs and re connect, let me know if this works. make sure correct oil level is checked mannually first.
  6. Re: oil level sensor
    May 2008
    Probably it will come back after 60 miles :-( same problem here, no need to disconnect the battery, just stop the engine, leave the keys in the ignition, and open the hood for a minute.
  1. Minimum Oil Level Light
    By Mike Brown in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2008, 07:01 PM
  2. Replies: 2
    Last Post: 30-11-2007, 07:04 PM
  3. GearBox Oil Level
    By Celtic Cousin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-09-2007, 08:03 PM
  4. Oil Level and yellow oil light
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-10-2006, 01:53 PM
  5. Coolant level
    By djsoftware in forum Passat - Archive Topics
    Last Post: 08-08-2006, 01:13 PM
