Thread: audi coupe cold start ???
  1. audi coupe cold start ???
    birmingham
    Hi all again,
    I have a cold start problem with my 89' audi coupe quattro
    its really difficult to start from cold and when i finally do get it going it runs rough for a few minutes.
    I have checked all the pipes for splits and the cold start injector is working fine.i also bled the rad and changed the temp sender on the bottom of the rad.
    its a 2.3i NG engine
    Any ideas ??
    rich
  2. Re: audi coupe cold start ???
    Gwent
    It sounds like you are not getting any cold enrichment, which could be a bad ECU temp sender. My guess is that it's the black 2 pin sender located at the top position on the water 'neck' coming out of the side of the head.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: audi coupe cold start ???
    birmingham
    Thanks man
    I'll change it and let you know
    regards
    rich
  4. Re: audi coupe cold start ???
    Dec 2007
    I have the same issue so would also be interested to hear what fixes this.
  5. Re: audi coupe cold start ???
    birmingham
    finally got round to sortin out a temp sender
    replaced it but it made no difference with cold start
    Any other ideas ??????
    tar
    rich
  6. Re: audi coupe cold start ???
    Gwent
    Sorry my advice did not work! if the exhaust fumes smell of petrol when it does get going, then it could be leaking injectors. There is a fuel accumulator on those cars, it is supposed to store a quantity of fuel, at pressure, ready for the next start, if the injectors leak, it gets dissipated and it may take some time for the fuel pump to refill the system.
    You could pull the injectors out and stand them in jars overnight, see how much fuel dribbles out? It is likely the O ring seals would be ruined doing this, so I would get new ones ready beforehand.
  1. Audi Quattro Coupe Cold Start??
    By sox in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 28-04-2009, 01:56 PM
  2. audi coupe cold start??
    Last Post: 31-10-2007, 02:46 PM
  3. audi 80 1.9 tdi wont cold start
    By rh-keith in forum 80 - 90
    Last Post: 16-08-2007, 02:49 PM
  4. Audi 80 2.0 SPI cold start issues?
    By panther12 in forum 80 - 90
    Last Post: 13-08-2007, 12:57 PM
  5. audi 80 cold start problem
    By chrispey in forum 80 - 90
    Last Post: 25-12-2006, 10:41 PM
