Thread: Rear Fog Lamp stopped working T4
  1. Rear Fog Lamp stopped working T4
    Dec 2007
    I've a T4 Westfalia camper from 1995 LHD.
    The rear fog lamp has stopped working.
    The connector seems clean and fine, and the bulb is intact. The fuse is OK too. The rocker switch is a two position switch and lights up, tho as far as I am aware front fogs were never fitted.
    Where should I look next? I'm not an expert on this sort of thing, but as it's a potential MoT fail I need to sort it.
    Ian
  2. Re: Rear Fog Lamp stopped working T4
    Hi You need to check the green on blue wire on the connector at the back of the bulb holder,with fog light on you should have 12v
  3. Re: Rear Fog Lamp stopped working T4
    Dec 2007
    Thanks very much.
    I'll try it at the weekend if not before - and let you know how I get on.
    Ian
  1. Radio stopped working!!
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 01:20 AM
  2. Sidelights stopped working
    By dib in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-12-2007, 11:08 AM
  3. Nearside Rear Window has stopped working???
    By nemo2182 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-06-2007, 10:10 PM
  4. Rear Wiper stopped working
    By Slur in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2007, 03:38 PM
  5. Circulation fan stopped working...
    By Trikster in forum Eos
    Last Post: 03-01-2007, 03:32 PM
