Thread: No power to cigarette lighter so no power to sat nav...
Results 1 to 9 of 9
  1. No power to cigarette lighter so no power to sat nav...
    Dfardon Guest
    I have just bought a TomTom sat nav and, not being a smoker, only realised when I plugged the sat nav power lead into the cigarette lighter that the front cigarette lighter has no power. Tried the rear cigarette lighter - same problem. The 12V supply in the boot works fine though. Anyone have any ideas where the problem might be?
    Car is an A6 2.5 V6 Tdi.
    Thanks!
  2. Re: No power to cigarette lighter so no power to sat nav...
    May 2007
    Poole
    I know this sounds daft - but have you checked the fuses? Though I suspect they are all on the same circuit.
    What about the one for the rear seat passengers - is that working?
    When I first had mine, the fuse for the two front sockets had gone and I can't remember if back one worked - but I think it did. One of the fuses had blown. Forgive me if you have checked this...
    Julian Whitehead
    2001 A6 Avant 2.7T Q
    Swing Unlimited | www.subb.co.uk | www.myspace.com/swingunlimitedbigband
  3. Re: No power to cigarette lighter so no power to sat nav...
    Sep 2007
    Hi Darfdon
    It will be the fuse. 15amp (blue). On the right hand side of dash is a panel pull it out to reveal the fuses. I can't remember which one it is but it's one of the middle ones. Your owners hand book should tell you, thirty something I think.
    Good luck.
    Rod
  4. Re: No power to cigarette lighter so no power to sat nav...
    Dfardon Guest
    Yeah, I looked througn the fuses but unfortunately the car was originally purchased in Germany, and so the handbook is also in German, so, not knowing any German, all I can do is check every fuse but they all seem fine. Unless anyone knows what the German is for "cigarette lighter fuse...". Or can just tell me which fuse relates to the front and rear cigarette lighters?
  5. Re: No power to cigarette lighter so no power to sat nav...
    Dfardon Guest
    Perfect, thanks Rod. I'll try again with the fuses.
  6. Re: No power to cigarette lighter so no power to sat nav...
    Dfardon Guest
    Ok, got it. Laborious translation of German manual reveals fuse 33 to be the one contorlling the cigarette lighters. And fuse 33 is missing, which is why I didn't find a dud fuse before. Changed it, and bizarrely, front cigarette lighter doesn't work as a fag lighter but will power the sat nav, which is good enough. Now, how do I keep the kids from playing with the now working rear lighter...?
  7. Re: No power to cigarette lighter so no power to sat nav...
    May 2007
    Do what I do. Put it in the glove box
  8. Re: No power to cigarette lighter so no power to sat nav...
    Dfardon Guest
    So no problem if they stick their little fingers in the cigarette lighter hole?
  9. Re: No power to cigarette lighter so no power to sat nav...
    Sep 2007
    No. Not the right sort of voltage. Only a problem if they stick metal in it then the fuse will blow again. Do what I did buy a torch that fits in the hole and recharges when plugged in, very handy.
  1. Cigarette lighter
    By Keeefff in forum Octavia
    Last Post: 29-06-2007, 09:22 AM
  2. Cigarette Lighter always on
    By SandLake in forum Passat - Archive Topics
    Last Post: 11-05-2007, 08:49 PM
  3. lighter problem
    By barbeler in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-02-2007, 09:51 PM
  4. Power source for Satnav / Phone Power
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 07-02-2007, 12:43 PM
  5. Cigarette Lighter (Drivers) What fuse? (bora uk)
    By mrhaun77 in forum Bora - 1998 - 2005
    Last Post: 15-01-2007, 12:13 AM
