Thread: blower heater resistor
  1. blower heater resistor
    how do i fit blower heater resistor on my m reg audi 80
  2. Re: blower heater resistor
    You will need to remove the glove box. You will then be able to see the blower motor. Just above this, to the right you should see some wires, these lead to the resistor pack. I believe the exact format varies depending on whether the car has air con or not, but mine just has a single retaining screw and a simple plug connection.
  3. Re: blower heater resistor
    Dec 2007
    Tenby, Pembrokeshire, United Kingdom
    Is it the same on the audi 90? as I need to change mine to?
  4. Re: blower heater resistor
    Not sure if the 90 will be the same, but it should be fairly similar. The part is generally near the blower motor which tends to be behind the glove box.
  1. eratic heater blower
    By jack in forum Audi A4 - Archive Topics
    Last Post: 07-12-2007, 09:54 AM
  2. 2003 Polo 1.2S Heater Blower
    By draghsone in forum Polo - Derby - Lupo - Fox
    Last Post: 03-12-2007, 07:39 PM
  3. S reg A3 - Accessing Heater Blower Motor
    By kimi in forum Audi A3 - Archive Topics
    Last Post: 26-10-2007, 10:54 AM
  4. Heater Blower
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2007, 03:05 AM
  5. NO HEATER BLOWER
    By EMILY in forum Passat - Archive Topics
    Last Post: 23-01-2007, 05:38 PM
