Can anyone think what my be causing the following:-
Both sides of the climate control ecu are set at 18 deg C. Drivers side has coolish air coming out of centre and side vents at say 18 deg C. Passenger side has air coming out at say 40 deg C. If I drop the temp on the passenger side down to low then cold air comes out.
Does anyone know if there is a dedicated temperature sensor for each footwell? If so, would this come up as a fault on the VAG check - nothing has been identified as a fault so far i.e. faults on the vent motors.
