Thread: Whining Gearbox ?
Results 1 to 10 of 10
  1. Thumbs down Whining Gearbox ?
    Southampton
    Own a VW Passat 1.9 diesel sport. Have whining noise.
    Seems to be gearbox but not sure.
    Help
  2. Re: Whining Gearbox ?
    May 2007
    West Midlands
    Quote Originally Posted by Carl E View Post
    Help
    year, manual, tiptronic or multitronic ?????
  3. Re: Whining Gearbox ?
    Coventry
    occurs in which gears, under acceleration or decellaration?
  4. Re: Whining Gearbox ?
    Southampton
    Occurs in all gears, out of gear, coasting and under acceleration.
    The noise only occurs whilst in motion, the noise does not change pitch when the rev's are increased.
  5. Re: Whining Gearbox ?
    does noise change pitch when turning corners? have you checked g/box oil? drain small amount of oil from box after long run,check for metal filings..
  6. Re: Whining Gearbox ?
    Aug 2007
    Northern Ireland
    Goes away when clutch pedal pressed in?
    52 plate Golf GT TDi
  7. Re: Whining Gearbox ?
    Southampton
    Noise is constant whether clutch is pressed or not. Pitch does not change when turning corners.
    Manual, six speed transimssion
    Have recently had car serviced starting to worry that oil levels may be to blame?
  8. Re: Whining Gearbox ?
    Jun 2006
    6 Post(s)
    Old thread I know, but did you ever sort the whining problem?. I cannot find a thread anywhere relating to this fault that comes to a conclusion. We have a Passat 6 speed with 301,000 miles that has started to do this.
  9. Re: Whining Gearbox ?
    Aug 2007
    Does the noise get worse when you reverse (quickly)
  10. Re: Whining Gearbox ?
    Sep 2017
    leicester
    hi guys im new on here got a issue with my vw sharan 2005 1.9 tdi sport 115 happens on 5th gear when relising acceleration its winning any idea what could it be i have read some adverts on here aswell as googled it said with driveshafts i replaced bothsides inch cv joint not got a clue what ment to do anymore been to mechanic and they think its the gearbox any advice is apririciated thank you
  1. Whining from front of engine
    By jtothek in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-10-2007, 05:30 PM
  2. Gearbox
    By KevinT in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2007, 06:05 PM
  3. Best gearbox oil
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2007, 12:09 PM
  4. Engine Whining
    By nigzy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2007, 11:54 AM
  5. aircon compressor whining
    By richardw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2007, 02:15 AM
