Thread: Top end Tapping noise BXE engine
  1. Top end Tapping noise BXE engine
    Apr 2024
    York
    I have a 2008 vw jetta with 1.9tdi bxe engine with a tapping noise which increases when acc is pressed I've change cam shaft
    lifters
    Injectors cam belt oil cam shaft sensor all to no avail. Should I swap engine or crack it open help!!!
  2. Re: Top end Tapping noise BXE engine
    1845 Post(s)
    Change the con rod bearings ASAP! The BXE is notorious for upper shell wear.
  1. Question Engine tapping noise Audi A6 2.0 TDI C&
    By Harv1969 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-10-2021, 06:07 PM
  2. BKD engine noise, loud tapping
    By dekhelia in forum Golf MK5 - 2004 - 2009
    Last Post: 08-04-2019, 08:44 PM
  3. Tapping & clicking noise from engine
    By bigjazzie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-07-2016, 08:45 AM
  4. Tapping noise from 2.3 Cabriolet NG engine
    By Soccy in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-05-2016, 06:10 PM
  5. tapping noise from engine
    By stof in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2008, 08:42 PM
