Thread: Oil dipstick
  1. Oil dipstick
    Mar 2016
    KEnt
    22 Post(s)
    Hi all
    So I've been having the max oil warning light pop up on my dashboard and wanted to drain some oil away. I was looking online and saw that you could siphon the oil out using the dipstick plug (followed YouTube video).
    However, I think I've found it but for the life of me I can't get it out, I can twist it but just can't pull it out.
    Just wanted to check it's the right plug I'm trying to pull.
    Thanks in advance!
    Sent from my SM-S908B using Tapatalk
  2. Re: Oil dipstick
    1842 Post(s)
    They can be very tight but why is your oil high? On the V6 TDI this can be injector or DPF problems.
  3. Re: Oil dipstick
    Mar 2016
    KEnt
    22 Post(s)
    Hey crasher, think it's because we use it only for short distances it's already 6.5 years in and has 35k on the clock.
    Get it serviced every year and seems to happen every 10-12 months in so goes away post service.
    Think it was posted about max oil before and it was something to do with fuel getting into oil sump due to failed regen because of the short journeys.
    I'll take it for a long run over the long weekend which should hopefully clear it.
  4. Re: Oil dipstick
    1842 Post(s)
    Yes it is a common DPF pain, low annual milage and DPF’s don’t work.
  1. Dipstick
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-05-2018, 08:03 AM
  2. Dipstick?
    By bloostar in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 15-06-2017, 01:41 PM
  3. I have no dipstick!
    By Black Phantom in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2015, 09:24 PM
  4. dipstick!
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-09-2011, 01:26 PM
  5. What a dipstick!!
    By jimgironde in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-07-2009, 09:57 PM
