Thread: Steering Lock : Contact Workshop.
Results 1 to 9 of 9
  1. Angry Steering Lock : Contact Workshop.
    Mar 2024
    Romania
    Hello!
    I have an Audi A4 B8 (2013) 2.0 TDI car. One day it gave me a "Steering Lock : Contact workshop!" fault, when I started the car. The steering wheel locks and unlocks perfectly when starting and stopping the car, there is no issue with the steering or the steering lock at all, it locks and unlocks itself.
    Yesterday the car didn't want to start, after pressing the key and the clutch down multiple times repeatedly it started. Drove it for 30 minutes, was sitting in a parking lot for 30-40 minutes, maybe even an hour, the fault code disappeared, the car started as usual with no problems at all. Today it threw out the fault code again, but this time the car starts normally, I just have the "Steering Lock : Contact Workshop" issue. Sometimes it disappeares and comes back right after starting it again , sometimes the fault does not come back on for a couple of days.
    The car was at a mechanic, the VCDS software didn't gave any fault codes for some reason, the mechanic couldn't clear the fault.
    Any ideas?
  2. Re: Steering Lock : Contact Workshop.
    1842 Post(s)
    The system is very sensitive to an even slightly weak battery.
  3. Re: Steering Lock : Contact Workshop.
    Mar 2024
    Romania
    So is there anything I can do? The battery was changed not even 2 months ago.
  4. Re: Steering Lock : Contact Workshop.
    1842 Post(s)
    You say there were no codes but he could not clear the fault, can you get a full car VCDS scan and post it?
  5. Re: Steering Lock : Contact Workshop.
    Mar 2024
    Romania
    Unfortunately I don't have the software, only the mechanic I went to. So I can't post it.
  6. Re: Steering Lock : Contact Workshop.
    Mar 2024
    Romania
    So the software game me an error at terminal 15 with 03026 fault code.
  7. Re: Steering Lock : Contact Workshop.
    1842 Post(s)
    Terminal 15 is the ignition live feed, we need to see a full car scan. preferably VCDS, and include the VIN as there my be other faults in different controllers which are relevant.
  8. Re: Steering Lock : Contact Workshop.
    Mar 2024
    Romania
    Still could not get a VCDS scan, because I do not have the software. The car does not start anymore only if my foot is on the clutch and push in the key several times until it randomly starts, but for the most part only ignition , nothing else.
    The "Steering Lock : Contact Workshop." fault is still on the dashboard , if the start-stop system stops the car, I put my foot back on the clutch, it start everytime without any problems. Only the key does not start the car.
  9. Re: Steering Lock : Contact Workshop.
    1842 Post(s)
    I sounds like the column lock unit is faulty.
  1. Replies: 6
    Last Post: 10-12-2021, 05:39 PM
  2. Pre sense fault please contact workshop
    By gebbel in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 30-01-2021, 03:50 PM
  3. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  4. Please Help Ignition Lock Defective - contact workshop - no ignition, car is a brick
    By paceman in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2019, 10:24 PM
  5. Steering lock fault : system fault! contact workshop.
    By DJS11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2017, 11:20 PM
