Thread: Starter relay circuit error... weird key behaviour
Results 1 to 9 of 9
  1. Starter relay circuit error... weird key behaviour
    Nov 2018
    Blackpool
    Hi all,
    After much headscratching and Googling I just can't get to the bottom of this - does anyone know what might be causing the following please?
    My 2013 Passat B7 has been having intermittent start issues to the point it has now become a complete non-starter. The code reader came out as saying "P308800 - Starter relay Electrical error in circuit". After quite a bit of diagnosing, I've tried replacing both starter relays, and have eliminated the relays and the starter motor as the issue. If I short-circuit starter relay 1 then the car starts fine (but still displays weird behaviour - see below). 12V is being supplied to the starter relay 1 coil, and also to the Normally Open starter solenoid wire. It's as if the ECU isn't commanding it to start.
    The other weird behaviour which I don't know if is the cause, or a consequence is that the push-key seems to be allowing a start when you turn the ignition on, without pushing it in fully to start. For example if you push the key to turn the ignition on (not fully into the start position), it flashes "Press clutch to start", and if the relay has been bypassed then this is when it starts.
    Ideas so far - ignition switch (local garage tried replacing this, but they were rushed so not sure they gave it a good go), BCM?, ECU?, starter relay 1 connection to ECU (but why the strange key behaviour)? There's a screenshot below of the OBDEleven code reader output, and also a screenshot of the 'live data' of the starter inhibition conditions. I don't have a decode for the starter inhibition conditions so haven't a clue what it actually means.
    (FYI the P253500 code only appears if the key has been left in the ignition without starting for a few minutes). The Exhaust Gas error might just be that I've been playing around with the MAF on and off while diagnosing this issue).
    Code:
    Date: 2024-01-30 13:27
        VIN: WVWZZZ3CZDE051229
        Car: Volkswagen Passat
        Year: 2013
        Body type: Variant
        Engine: CAYC
        Mileage: 398710 KM
    01 Engine
        System description: 1,6l R4 CR td
        Software number: 03L906023FS
        Software version: 9626
        Hardware number: 03L907425C
        Hardware version: H43
        Serial number: 00000000000000
        ODX name: EV_ECM16TDI02103L906023FS
        ODX version: 003008
        Long coding: 00194014030501080000
        Trouble codes:
            P040200 - Exhaust Gas Recirc.Flow Excessive Detected
                static
                    Mileage: 398713 km
                    Priority: 2
                    Malfunction frequency counter: 1
                    Unlearning counter: 255
                    Engine speed: 779.50 1/min
                    Normed load value: 32.2 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 45 °C
                    Intake air temperature: 23 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 14.908 V
                    Dynamic environmental data: 2096282037279F29D1049A20A7000020BA7AB6202930CE202A30CE2002061A
                static
                    Mileage: 398713 km
                    Priority: 2
                    Engine speed: 0.00 1/min
                    Normed load value: 0.0 %
                    Coolant temperature: 41 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.536 V
                    Dynamic environmental data: 209628F40C0000F40D002A076F20D6023E0A5B
            P253500 - Ignition Switch Run/ Start Position Curciut High
                static
                    Mileage: 398713 km
                    Priority: 2
                    Coolant temperature: 40 °C
                    Voltage terminal 30: 12.424 V
                    Dynamic environmental data: 209628F40C0000F40D002A076E20D6023E0A593F8300
    03 Brakes
        System description: J104   C2 450M V468
        Software number: 3AA614109AF
        Software version: 0024
        Hardware number: 3AA614109AF
        Hardware version: K03
        Serial number: 00000006145874
        Coding: 0002983
        Trouble codes:
            No trouble codes found
    04 Steering Angle Sensor
        Trouble codes:
    08 Air Conditioning
        System description: AC Manuell
        Software number: 7N0907426BG
        Software version: 0505
        Hardware number: 7N0907426BG
        Hardware version: H20
        ODX name: EV_ACManueBHBVW36X
        ODX version: A01010
        Long coding: 0010004003
        Trouble codes:
    09 Central Electrics
        System description: BCM PQ47 M
        Software number: 3AA937087F
        Software version: 0465
        Hardware number: 3AA937087F
        Hardware version: 421
        Long coding: 0008000000000000009800801000006403010088424D81606480C7200041
        Subsystems:
            System description: Wischer 22081
            Software number: 3AC955119
            Software version: 0612
            Hardware version: 26
            Long coding: 00B795
        Trouble codes:
    15 Airbag
        System description: J234__108 VW10 HI
        Software number: 5N0959655AA
        Software version: 2118
        Hardware number: 5N0959655AA
        Hardware version: 003
        Serial number: 003L7PJ1PWHL
        Coding: 0012344
        Trouble codes:
    16 Steering Column
        System description: LENKS.MODUL
        Software number: 3C9953501BF
        Software version: 0140
        Hardware number: 5K0953569S
        Hardware version: 014
        Serial number: 20120821300106
        ODX name: EV_VW360SteerWheelUDS
        ODX version: A03004
        Long coding: 1182250000
        Subsystems:
            System description: E221__MFL-TK6
            Software number: 3C8959537D
            Software version: 0022
            Hardware version: H07
            Long coding: E20000
        Trouble codes:
    17 Dashboard
        System description: KOMBI
        Software number: 3AA920970J
        Software version: 0705
        Hardware number: 3AA920970J
        Hardware version: H05
        ODX name: EV_Kombi_UDS_VDD_RM09
        ODX version: A04716
        Long coding: 461F00
        Trouble codes:
    19 Gateway
        System description: J533  Gateway
        Software number: 7N0907530T
        Software version: 1632
        Hardware number: 7N0907530K
        Hardware version: H40
        Serial number: 140812F2001967
        Long coding: 462007
        Trouble codes:
    25 Immobilizer
        System description: IMMO         045
        Software number: 3AA959433
        Software version: 0400
        Hardware number: 3AA959433
        Hardware version: 008
        Serial number: VWZCZ000000000
        Subsystems:
            System description: ELV          029
            Software number: 3C0905861J
            Software version: 0380
        Trouble codes:
    2E Media Player 3
        System description: SG EXT.PLAYER
        Software number: 5N0035342F
        Software version: 0546
        Hardware number: 5N0035342F
        Hardware version: H18
        Serial number: 7663344392
        Long coding: 010100
        Trouble codes:
    42 Driver Door
        System description: TUER-SG FT
        Software number: 3AA959701
        Software version: 0534
        Hardware number: 3C0959793B
        Hardware version: 002
        Serial number: 0005268577
        ODX name: EV_TSGFPQ35BRFVW46X
        ODX version: A04001
        Long coding: 0202B5
        Subsystems:
            System description: J389__TSG-HR
            Software number: 3AA959704A
            Software version: 0503
            Hardware version: 004
            Serial number: 00000003100142
            Long coding: 010290
        Trouble codes:
    44 Steering Assistance
        System description: EPS_ZFLS Kl. 194
        Software number: 1K0909144P
        Software version: 3305
        Trouble codes:
            03803 - Steering angle sensor for power-assisted steering
                static
                    Priority:  2
                    Frequency counter:  1
                    Driving cycle: 255
                    Mileage: 398713 km
    46 Comfort System
        System description: KSG PQ47 ELV 045
        Software version: 0634
        Long coding: 019102005A830E76340494157C085FCE105801
        Subsystems:
            System description: LIN BACKUP HORN H05
            Software number: 1K0951605C
            Software version: 1501
            System description: Neigungssensor  004
            Software number: 3C0951171C
            Software version: 0611
            System description: Innenraumueberw.004
        Trouble codes:
    4F Central Electrics 2
        System description: EZE_2
        Software number: 7N0907532
        Long coding: 00000008
        Subsystems:
            System description: Analoguhr
            Software number: 3AA919204A
            Software version: 0004
        Trouble codes:
    52 Passenger Door
        System description: TUER-SG BT
        Software number: 3AA959702
        Hardware number: 3C0959792B
        Serial number: 0005264885
        ODX name: EV_TSGBPQ35BRFVW46X
        ODX version: A04001
        Long coding: 0202B4
        Subsystems:
            System description: J388__TSG-HL
            Software number: 3AA959703A
            Serial number: 00000003100831
            Long coding: 010290
        Trouble codes:
    53 Parking Brake
        System description: J540 EPB4  VW-86594
        Software number: 3AA907801H
        Software version: 0010
        Hardware number: 3AA907801H
        Serial number: 00000000415120
        Coding: 0022167
        Trouble codes:
    56 Radio
        System description: Radio RCD310
        Software number: 1K0035186AQ
        Software version: 0119
        Hardware number: 1K0035186AQ
        Serial number: VWZ1Z2M9669314
        Long coding: 01000400040011
        Trouble codes:
    61 Battery Regulation
        System description: Batt.regelung
        Software number: 7N0907534
        Long coding: 030F1859
        Subsystems:
            System description: J367-BDM
            Software number: 1K0915181H
            Software version: 0180
            Serial number: 00000000008900064955
        Trouble codes:
    62 Rear Left Door
        Trouble codes:
    72 Rear Right Door
        Trouble codes:
    77 Telephone
        System description: TELEFON
        Software number: 7P6035730J
        Software version: 3200
        Hardware number: 7P6035730J
        Hardware version: H15
        Serial number: 00007663308760
        ODX name: EV_UHVNA
        ODX version: 002720
        Long coding: 0A01000000010101
        Trouble codes:
  2. Re: Starter relay circuit error... weird key behaviour
    1841 Post(s)
    I would start, sorry, begin by replacing the two starter relays 643 (now 645) 4H0 951 253 A and 489 6Q0 951 253 in the supplementary relay holder at positions 1 and 6 respectively.
  3. Re: Starter relay circuit error... weird key behaviour
    Nov 2018
    Blackpool
    Thanks Crasher, tried that earlier - still doesn't help but I can tell that the smaller 489 clicks correctly but it's the 643 that doesn't click at all. 12v is supplied correctly to the 643 solenoid.
    If I bypass relay 643 with a small wire then it starts correctly... but the weird key behaviour still happens.
  4. Re: Starter relay circuit error... weird key behaviour
    1841 Post(s)
    New switch unit next although the data I can see at home is confusing.
  5. Re: Starter relay circuit error... weird key behaviour
    Nov 2018
    Blackpool
    Sorry do you mean ignition switch? If I get a matching used part off ebay with a linked key then is this just plug and play or does it still need to be coded in? Cheers!
  6. Re: Starter relay circuit error... weird key behaviour
    1841 Post(s)
    It isn't a coded part or vehicle specific, part number 3C0 905 843 AE and £93.60 retail inc VAT. Used electronic parts are a mugs game. However, sometimes the central electrics unit is the problem and they get seriously complicated to replace as they are a Vehicle Intelligent Part, special order from Germany in many cases, have to be paid for up front (£526.80), cannot be canceled or returned for ANY reason EVEN if found to be faulty straight out of the box. In that situation you have to engage in the fun of a TPS warranty claim, solving the Israel Gaza crisis is less complex and more achievable! Also with the type 36 the central electrics has a trick up its sleeve. It comes locked and needs coding, if you try and do this with anything other than ODIS it has the potential to screw up the coding on nearly all the cars controllers and in one case recoded the ABS pump for left hand drive and locked the ECU making the car pull to the left and the ABS light stuck on. The only way to get around it was a new ABS unit... try explaining that one to a customer!
  7. Re: Starter relay circuit error... weird key behaviour
    Nov 2018
    Blackpool
    Thanks for the detailed reply! Crikey that CCM is expennnsive... almost not worth it for a 250k mile car! Would hate to scrap it just because of an electrical gremlin though... what a waste!
    Another gremlin appeared last week, in that whenever I unlock the car using the keyfob (or press the 'unlock all doors' button inside) the boot motor operates and pops the boot open slightly. The switch on the tailgate doesn't operate, however OBDEleven shows that the car knows when the switch is operated, but it just doesn't open the boot!! No faults from CCM but do you think it's safe to assume it's combined with the ignition key issue and it might be corrosion on the module?
    Cheers!
  8. Re: Starter relay circuit error... weird key behaviour
    1841 Post(s)
    I am in the process of spending £100K on a 1995 Audi 80...
  9. Re: Starter relay circuit error... weird key behaviour
    Nov 2018
    Blackpool
    £100k, that's dedication!!
    I've had another couple of issues appear with the electrics - the boot unlock doesn't work, and the fuel tank filler lock is throwing up an error. There's defo no prob in the wiring as I checked continuity to the Central Convenience Unit, so if this module's dodgy then could it also be the cause of the ignition problem?
    If this error is present "P253500 - Ignition Switch Run/ Start Position Curciut High" would the ECU prevent sending a terminal 15 signal to activate the starter relays?
    Sorry, so many questions, I'm so confused - hoping it's not one of the modules!
  1. Please Help starter motor problem - P305300 open circuit terminal 50
    By simonavo in forum A8 - S8 - V8
    Last Post: 20-10-2020, 10:04 PM
  2. Help with load reduction circuit after pulling relay
    By ironman55 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2018, 11:49 AM
  3. A3 1.9TDI 2003 weird behaviour with dying battery
    By michaelab in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-10-2012, 07:01 PM
  4. Question Weird rear wiper behaviour
    By KieranM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-04-2012, 08:21 PM
  5. Question Weird Aircon Behaviour. . . .
    By ::SPG:: in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-09-2010, 11:48 PM
