Thread: Water ingress probs
Results 1 to 10 of 14
  1. Water ingress probs
    Hi everyone, glad i found this website. I own a S plate 110 passat with 184,000 miles, over all this car has been fairly solid but recently i have noticed water dripping down from under the front passenger foot well. All the carpets appear to be dry and all engine fluid levels are fine. I have looked underneath and there doesnt appear to be any pipes running where the drip is?
    I have read before that passats are prone to water ingress around this area but cant remember what the cause was?
    Any suggestions?
    Aug 2006
    Devon, UK
    The usual reason for passenger side carpets getting wet is a busted pollen filter seal. However, if your carpets are dry it may not be this.
    Is the water leaking from under the car?
    If so, it may be condensation from the air conditioner that can often be seen in humid conditions. If you suspect it might be this, try switching off AC and see if the problem persists.
    Let us know what you find.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    thanks for the info, i checked the pollen filter and it looks to be dry (and very dirty, nice to see vw do what they say in a service....!) I did find both drainage holes blocked but the leak is still there. I drove with the air con off and it didnt leak when i stopped the engine. I know u were saying about condensation but i think there is a problem as a trail of water runs across the road once parked. How do i check the pollen filter seal so i can rule this out once and for all
    Aug 2006
    Devon, UK
    I had some drips from the same place as you today after running my Air Con. It was only a few cc's of water though. If all your engine levels are fine, and the water is under the car, not in the car, it must be something to do with aircon since it stopped when you turned it off.
    Is it definately water? There will be gas in the Air Con system, not a liquid.
    If it was the pollen filter seal you'd get wet carpets on the passenger side after heavy rain, so it's not that.
    Perhaps you just have very effective aircon and it's particularly humid where you are. It could just be as simple as that!
    100k miles
    Ok i could see the water running down then finally dripping off under the foot well, it goes up towards the battery tray, i took the tray out but it was fairly dry underneath. I feel a trip to an air con specialist coming on...
    Just another quick question, how does a busted pollen filter seal cause a water leak? i thought that was just air?
    Aug 2006
    Devon, UK
    When it rains, water can run down the bulkhead area and it gets inside the car through a pollen filter seal... (I think!)
    100k miles
    Jun 2006
    Droitwich, Worcestershire
    Thought i might drop this one in, have you checked the windscreen seal?? I had one go once and it took me ages to find out where the water was coming in from! Turned out all it needed was some silicone sealant behind the seal and problem solved.
    Might not be the prob in your case, but thought i would mention it!
    Good luck
    Aug 2006
    Hi I also had the same problmm on my Passat. In my case it too was the pollen filter housing. From memory I ended up buying some 4inch black inulsation type tape, and then took the pollen filetr out, and taped up the inside vertical side of the housing. I also has some spray waxoyl which I then used to careful spray around the outside of the hosuing, partcularly on the right hand side where it come close the the wing. In my case this solved the probelem. Might do the same for you too.
  10. Angry water leak mark 4 polo
    does anyone know where the drain holes are for mark 4 polo. next to pollen filter as my car leaks water when it rains and i cant c when im driving when i puton the heater. call me or email 07894053305 ASAP please andricos2000@yahoo.co.uk
  1. Water ingress in Boot on Golf Mk 4
    By tobert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 12:11 PM
  2. Water ingress/CCM failure
    By quantum_man in forum Passat - Archive Topics
    Last Post: 14-03-2007, 12:01 PM
  3. Water ingress.
    By Whocantellyer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-03-2007, 03:57 PM
  4. Water Ingress?
    By kriskros in forum Passat - Archive Topics
    Last Post: 26-12-2006, 08:09 PM
  5. Water ingress probs
    By SosolidVw in forum Passat - Archive Topics
    Last Post: 19-09-2006, 01:18 PM
