Thread: Water ingress probs
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Quote Originally Posted by andricos View Post
    does anyone know where the drain holes are for mark 4 polo. next to pollen filter as my car leaks water when it rains and i cant c when im driving when i puton the heater. call me or email 07894053305 ASAP please andricos2000@yahoo.co.uk
    andricos, i think you could do with posting this seperatly under a differnt thread, your problem doesnt sound the same as above, a little more info will be needed before people can advise you.
    Apr 2007
    warrington
    check the windscreen see if has been changed you can tell by the makers name in the corner of the glass it should say vw or xxx the steaming in the car is a tell tale sign that is been happening for a while
  3. Re: Water ingress probs
    I have a 2001 Passat Estate which suffered the same water ingress problem after last weekend's downpours. Pool of water 1 inch deep in rear passenger's footwell also affecting the front passenger's. Can anyone advise best menthod of drying out the carpet once the problem is fixed. I've been told to aqua vac it - anyone done this? Which aquavac to use? Also how easy is it to lift up the carpet? I don't want to get into the huge task of removing the seats. Any help appreciated.
    Brib C
  4. Re: Water ingress probs
    to dry out properly itd best to remove seat as the carpet is really stiff and this will give you access to the underneath along that side but anyway i had the dreaded leak and went to local vw dealer peter cooper in southampton they gave me new seal free looks live a stick off liquorice car now dry and all the electrics work properly
  1. Water ingress in Boot on Golf Mk 4
    By tobert in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-05-2007, 12:11 PM
  2. Water ingress/CCM failure
    By quantum_man in forum Passat - Archive Topics
    Last Post: 14-03-2007, 12:01 PM
  3. Water ingress.
    By Whocantellyer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-03-2007, 03:57 PM
  4. Water Ingress?
    By kriskros in forum Passat - Archive Topics
    Last Post: 26-12-2006, 08:09 PM
  5. Water ingress probs
    By SosolidVw in forum Passat - Archive Topics
    Last Post: 19-09-2006, 01:18 PM
