Thread: Mk5 jetta 2.0t brakes
  1. Mk5 jetta 2.0t brakes
    Mar 2021
    montreal,canada
    Went to get my car out of storage no brakes everything was fine when I stored the car I did the brakes front to back before putting it away.
    There's no leaks on the floor I checked all wheels for drips everything is dry.Checked the reservoir it's very low so I topped it off the level went down almost instantly.Brake pedal goes to the ground I get a little pressure just before the carpet.
    I unplugged the vacuum to the booster to see if it was wet no idea what's wrong or where the fluid is going.
    I don't have a lift so ill have to jack up the car remove the wheels to check everything thoroughly and check all the bleeders im suspecting air in the lines but how?
    Anyone have an idea why I would go from no issues perfectly working brakes to nothing.
    One thing I have to mention when I bought the car I kept having to top off the fluid cause the brake light would beep and flash but it was due to the rear pads wearing thin so I changed discs&pads everything is new front to back.
    Sent from my XP8800 using Tapatalk
  2. Re: Mk5 jetta 2.0t brakes
    1840 Post(s)
    if there are no visible leaks it must be going into the servo.
  1. Changed front brakes. Now no brakes!
    By g60bv in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-06-2018, 11:43 PM
  2. Volkswagen Jetta 2007 Jetta 2.0 TDI 140BHP Knackered Turbo?
    By VolksPolo in forum VCDS - General Questions
    Last Post: 10-11-2017, 02:11 PM
  3. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  4. I Need Help With My Jetta!!!
    By Maiko in forum Chat - Anything with wheels
    Last Post: 04-11-2007, 12:52 AM
  5. Upgrade A6 brakes to S8 brakes
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 10:15 PM
