Thread: 3.0tdi fuel consumption dropped significantly - no fault codes
Results 1 to 10 of 19
  1. 3.0tdi fuel consumption dropped significantly - no fault codes
    Hi All
    The fuel consumption has dropped significantly on my 2012 3.0tdi A6 Avant.
    Ive just got back from my garage who scanned it using his snap on unit.
    The only thing that looks amis is:
    'coolant temperature at radiator outlet' is showing 15.4 degrees C
    The line underneath is:
    'coolant temperature at radiator outlet - SPEC' and this is showing 93.5 degrees C
    Couple of questions:
    1. Is the 'coolant temperature at radiator outlet - SPEC' the expected value?
    2. If the 'coolant temperature at radiator outlet' is low (15.4 degrees) would this cause the ECU to over fuel?
    The coolant reservoir is certainly a lot warmer than 15 degrees so I can only presume this sensor is reading incorrectly....?
  2. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    May 2013
    Cheshire
    11 Post(s)
    What is your reference? When was that over? Last 2-3 weeks were really bad for fuel efficiency due to low temps.
    63 reg Ibis White A6 2.0 TDI SE Multitronic, Tech pack, folding mirrors, rear view camera, heated seats.
  3. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Quote Originally Posted by Olio View Post
    This has happened steadily since about September last year.
    When I used to fill the tank it would give me a range of 590-610 miles, this has steadily dropped to 460miles range now.
    In reality, I was getting 560ish miles a tank, Im now getting 390 miles before the fill warning comes on.
    Ive tried supermarket fuel, shell fuel, shell super diesel stuff and it doesn't make any difference.
    Theres definitely something wrong...
  4. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    May 2013
    Cheshire
    11 Post(s)
    Yes, it seems you're right. About the coolant temp, I read them like you. Expected temp 90+, read 15+
    Maybe a sensor issue, or an air bubble in the system? (Cf Coolant temperature actual V specified value | Ross-Tech Forums )
    The 3.0 TDI avant is the car I should have bought I i had known better then
  5. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Has anyone else any thoughts?
    Or any experience of the snap on diagnostic unit?
    Is the SPEC value the expected value?
  6. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Can anyone assist me in the part number for the radiator outlet sensor? I’m going round in circles searching for it and it’s interrupting my Saturday night beers 😬
  7. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Jul 2016
    Chestfield kent
    81 Post(s)
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  8. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
  9. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Is the radiator outlet sensor 06A 919 501 A
    Or is this the sender to the dash board?
    Nothings ever clear or easy is it?
  10. Re: 3.0tdi fuel consumption dropped significantly - no fault codes
    Aug 2009
    cheshire
    6 Post(s)
    98 Post(s)
    Thats the one. £46.80. Same one used across a lot of models. Interior temp sensor is on the dashboard and air temp sensor for engine management is on the front bumper bar
    RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  1. 2.0TDI Multitronic Fuel Consumption ?????????
    By pitch3110 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-02-2015, 07:51 PM
  2. Fuel consumption has dropped.
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-01-2014, 10:48 AM
  3. 2.0TDi Fuel Consumption
    By bikeman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2011, 05:52 PM
  4. Please Help Fuel Consumption has dropped
    By pacward in forum Bora - 1998 - 2005
    Last Post: 25-10-2008, 09:29 PM
  5. What is your fuel consumption for 2.0TDI
    By DobarDabar in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-07-2008, 04:11 PM
