Thread: 1.6 alz coolant bleed screw on metal pipe snapped
  1. 1.6 alz coolant bleed screw on metal pipe snapped
    Mar 2020
    ireland
    6 Post(s)
    My b6 1.6 alz coolant bleed screw is snapped off and leaking, it was a plastic one. Will i have to replace whole metal pipe or can a new screw be bought that said removing the old one might be difficult.
    Can anyone supply a part number for both items? My local dealer wont give out part numbers so ill have to buy there if i cant get a number
  2. Re: 1.6 alz coolant bleed screw on metal pipe snapped
    1840 Post(s)
    The "seal bolt" WHT 000 316 was dropped in November last year so unless you can find one stuck at a dealer you have to change the pipe to 06B 121 070 N with the new metal "seal bolt" which is £107.92 instead of £4.98 if VAG could be bothered to still sell it!
  3. Re: 1.6 alz coolant bleed screw on metal pipe snapped
    Mar 2020
    ireland
    6 Post(s)
    Thanks Crasher, can get the plastic screw from ebay either latvia or Lithuania but some time for delivery ill ring my local audi nd vw see if either has one
  4. Re: 1.6 alz coolant bleed screw on metal pipe snapped
    Mar 2020
    ireland
    6 Post(s)
    My local audi said they have one, are they hard to extract when broken? Any tips? Im hoping to collect it tomorrow. I have another thread about my p/s pump ive just ordered a new one will i need to replace the crush washers on the high pressure line? If so i can pick up two tomorrow at the audi garage
  5. Re: 1.6 alz coolant bleed screw on metal pipe snapped
    1840 Post(s)
    Yes use new washers, it is good practice. Really you need to remove the pipe to extract the screw with some gentle heat and then chase the thread which from alcohol fuddled distant memory is M10x1.25.
  6. Re: 1.6 alz coolant bleed screw on metal pipe snapped
    Mar 2020
    ireland
    6 Post(s)
    Got the bleed screw done bit of a faff to be fair, i got 90% of it out but I believe a small amount of the plastic bits got into my coolant system, I removed the pipe in the end, i had to re thread it and clean where the o-ring sat as it was very dirty and somewhat rusty. But its not leaking anymore i was sick of topping off the coolant. Theres a note in the service history from 2010 saying the head of bleed screw snapped of and was leaking! But obviously never replaced.
  1. Metal intercooler pipe damage
    By 28avant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2020, 11:56 PM
  2. Please Help i need to source a metal water pipe for 1.8! helppp!!
    By ziggy480 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2012, 07:45 PM
  3. Question Very Quick Question!! Bleed Screw
    By Grolly in forum Polo - Derby - Lupo - Fox
    Last Post: 21-06-2011, 04:43 PM
  4. metal coolant pipe on TDi
    By Golf tdi Hal in forum Golf MK3 - 1993 - 1999
    Last Post: 19-05-2010, 08:49 PM
  5. coolant bleed screw sheared?
    By MATN in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2009, 01:00 PM
