Thread: 3.0tdi dpf and turbo problem
  1. 3.0tdi dpf and turbo problem
    Nov 2015
    GB, SOMERSET, TAUNTON
    Hello guys, have issues with dpf pressure sensor and turbo.
    009300 - Diesel Particle Filter; Differential Pressure Sensor
    P2454 - 001 - Short to GND - Intermittent
    I GET THIS CODE RANDOMLY AND every time IM KICK GAS, TRIED DRIVE SENSIBLE BUT HIT EVERY POTHOLE IN THE ROAD, BUT CODE NOT COME BACK. AFTER FEW FAULT CODE COUNTS I GET
    008194 - Particulate Trap Bank 1
    P2002 - 001 - Efficiency Below Threshold - MIL ON
    AND LATER
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 - 009 - Electrical Malfunction - Intermittent ,
    CHECKED TURBO DUTY CYCLE AND ITS GOOD (REQUESTED 20.5% ACTUAL 20.9%)(REQUESTED 80.9% ACTUAL 80.9%)
    IGNITION ON, ENGINE OFF
    DIFFERENT PRESSURE 0mBar
    DIFFERENT PRESSURE OFFSET 0mBar
    OIL ASH VOLUME 0.28
    CARBON MASS (CALC) 13.0
    CARBON MASS (ACTUAL) 12.5
    MILEAGE SINCE LAST REGEN 1030KM
    ENGINE ON, IDLE
    DIFFERENT PRESSURE -14mBar
    OIL ASH VOLUME 0.28
    CARBON MASS (ACTUAL) 0
    BOUGHT NEW SENSOR, BUT COULD NOT FIND RIGHT INFO HOW TO ADAPT NEW SENSOR. IF I GO CODING II BALOON WITH CODES IS ONLY FOR FORCE REGEN AND CRUISE CONTROL ACTIVATION. SENSOR IS 100£ SO BEFORE FIITNG NEED TO BE SURE FOR CORRECT PROCEDURE?
    ALSO WHICH TUBE NEEDS COMPRESSED AIR BLAST THE SMALLER ONE OR BIGGER one?
  2. Re: 3.0tdi dpf and turbo problem
    1840 Post(s)
    The turbo actuator has to be bench set up using specialist calibration equipment, a lot of people get it wrong. If you have VCDS, the sensor adaption should be in the basic settings list but you have to log in first.
  3. Re: 3.0tdi dpf and turbo problem
    Nov 2015
    Hi Crusher. Done basic output test and its within limit
  4. Re: 3.0tdi dpf and turbo problem
    Nov 2015
    Adaptions are available onlyfor forced regen and cruise control in CODING II.
  1. A6 2.0tdi turbo problem
    By markashman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 06:35 AM
  2. A6 3.0TDI Turbo startup
    By colinrea in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-04-2015, 08:59 PM
  3. Audi a3 8p 2.0tdi bkd turbo
    By Martynas26 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-10-2014, 11:28 AM
  4. A3 2.0tdi Turbo Noise
    By as400 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-01-2013, 10:07 AM
  5. Please Help a4 2.0Tdi turbo probs
    By S_Line in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2010, 06:45 PM
