Thread: Matrix led headlight adjustment
  1. Matrix led headlight adjustment
    Mar 2012
    Ireland
    Iíve just had my nct test ( Irish mot) and failed for dipped beams being too high!
    Does anyone know how to adjust the headlights on a c7.5 with matrix led lights?
    I canít find anything on the topic and canít see any obvious adjustment screws.
    There is some conventional light adjustment procedures but not one for matrix.
    I have vcds so can run adaptations if needed.
    I thought the car used level sensors to adjust the headlights all the time.
    Bemused........
  2. Re: Matrix led headlight adjustment
    Aug 2009
    cheshire
    6 Post(s)
    84 Post(s)
    Matrix lights work differently to normal lights but they still need physically adjusting in order to get them at the correct height. There are white screw that adjust them fitted to the headlights. In VCDS you should be in basic settings before you do the physical adjustment so that it learns the new position.
    Usual info like point car at a white wall etc should be done.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill plates,Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  1. How To Matrix headlight - change the switching intensity
    By onakvee in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-11-2020, 03:21 PM
  2. Matrix headlight upgrade
    By Tezargh in forum Q7 - 4M Forum - 2016 -
    Last Post: 22-09-2020, 10:14 AM
  3. Matrix : Headlight Assist
    By ivwaudi in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 06-03-2018, 09:35 AM
  4. Condensation in Matrix headlight
    By srbsq7 in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-11-2016, 08:20 AM
  5. Headlight adjustment
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 29-10-2013, 08:25 PM
