Thread: OEM Electric Swivel Towbar Installation Help
  1. OEM Electric Swivel Towbar Installation Help
    Oct 2019
    Scotland
    I've managed to acquire an oem electric swivel towbar, which im hoping to install on my late 2016 Q7. Looking at the PR codes my q7 doesnt have towbar prep. So i'm wondering if anyone has previously retrofitted the oem swivel towbar and would be able to share any info.
    From the research i have already done i will need the towbar module 4M0 907 383 and the switch for in the boot. Also i'll need the wiring that goes between the towbar module and the convenience module?
    Is there anything else i will need?
    Any help is greatly appreciated.
  2. Re: OEM Electric Swivel Towbar Installation Help
    Oct 2013
    Home
    Longer bolts, the crash bar you will remove has shorter bolts holding it on.
    Aside from that, it's a relatively easy physical install, install the loom and module in the boot, bumper off, bolt the bar on, cut the bumper, back on.
    Coding is not so simple, lots of modules need to know about the new addition, but that's possible also 👍
  3. Re: OEM Electric Swivel Towbar Installation Help
    Oct 2019
    Scotland
    Paul,
    Thanks for your reply, do you know if the loom is available from audi or is the Kufatec loom the best option? I have VCDS for the coding, however need to find the details of what coding changes are required?
    Did you do the install yourself?
  1. [How to]Swivel towbar electric harness a6 4f
    By jocker01 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 31-03-2019, 02:42 PM
  2. Audi Factory Fit Swivel Towbar
    By terry.hatton in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 02-03-2019, 12:07 PM
  3. Replies: 5
    Last Post: 10-04-2018, 06:05 PM
  4. Audi A6 C6 Avant 2008 retrofit swivel towbar - Please Help
    By i0zjh02 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 10-10-2014, 10:00 AM
  5. Rear bumper removal for towbar installation
    By makemineamythos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 07:35 AM
