Thread: B6 a4 cvt issue
  1. B6 a4 cvt issue
    Jan 2021
    GB worcester
    I have an a4 avant b6 1.9tdi with the dreaded cvt box, i have papework for a brand new transmission along with clutch pack etc back in 2013
    When in drive the car will judder when pulling away almost like stalling a manual, if i gently give it throttle it will pull away fine, when movong it drives and shifts perfectly, no judder when coming to a stop or when actually moving though. When sat in drive the car doesnt want to take off when releasing the brake like a normal automatic does too, i have to accelerate for it to move.
    Currently waiting for the special key to turn up to be able to service the box to see if that makes a difference but does anyone have any idea what could be causing it?
    Also does anyone know where i would be able to order/buy a replacement clutch pack if thats possibly the issue?
    Sent from my DUA-L22 using Tapatalk
  2. Re: B6 a4 cvt issue
    Apr 2013
    gosport uk
    I also have the cvt. So far I have had the display flashing and luckily this was rectified by the place I bought it from. As time went on the car juddered would not pull away properly and the reverse was not good. I eventually gave in after putting a new clutch/flywheel in and having the oil changed twice. I took it to a gearbox specialist who charged the best part of £2.7k to rebuild the box. I would not say it is perfect as I still get judders occasionally and the reverse clunks more often than not. I guess what I am trying to say is the cost of this repair will be more than the car is worth. I have spent in the region of £7k over the last 4 years to keep the b6 1.9 tdi saloon on the road. When I drive it the ride is very good and with the new turbo (£2K repair job) my conclusion is that next time it goes wrong I will buy another car.
  3. Re: B6 a4 cvt issue
    Jan 2021
    GB worcester
    Quote Originally Posted by a4cvt View Post
    Mine only does it in drive, im hoping a flush and new fluid and then an adaptation fixes it, it already had a new box and clutch etc so im ruling that out for now, but if worst comes to worst im a fully qualified technician so if i can source the parts ill rebuild it all, i havent had any lights flashing or any fault codes for it so i dont think its fatal yet
  4. Re: B6 a4 cvt issue
    1837 Post(s)
    The only source I know is genuine, the two forward disc sets 01J 398 944 and 01J 398 941 come to £145.10 but there are a few other parts need to install them such as gasket set, circlips and of course, fluid. If you search "01J rebuild" there is quite a lot of info and service kits.
  1. Issue with 2019 Q7 50 TDi - Hesitation from speed sensor issue
    By marcusjames in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-02-2020, 06:01 PM
  2. 4.0 TDI d3 EGR issue
    By erubus in forum A8 - S8 - V8
    Last Post: 18-03-2017, 07:39 PM
  3. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  4. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
