Thread: Key - need some good advice
  1. Key - need some good advice
    Jan 2021
    Donaghcloney NI
    Hi Folks,
    I have a 2008 VW Golf Estate 1.9tdi and my daughter has a 2012 VW Polo 1.2tdi both cars come with only 1 key!!!
    I am looking to get a remote spare key for both vehicles, what is my best options?
    What do VW charge?
    Am I better to go to an auto locksmith?
    or can I buy a remote key (with circuit board) of eBay and get it cut? Then can I program it myself?
    are all VW keys 434 hz?
    any advice very welcome.
    Thanks.
  2. Re: Key - need some good advice
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    VW will be pricey! Auto electrician might be the cheaper option. Not sure if you can reprogramme keys with VCDS....
    Looks like it’s possible if you check the Ross tech site.
    Ross-Tech: VAG-COM: Remote Control Matching Info
    But I’m not sure about the immobiliser part of the key....if it’s not matched to the car / cluster it won’t turn on.
    Normally cars come with 2 keys so clearly they’ve gone missing....
    Let us know how you get on.
  3. Re: Key - need some good advice
    Jan 2021
    Donaghcloney NI
    Key Generic Blank ID48 VW Golf Passat Polo Skoda 1J0959753AH 100% Tested | eBay
    I take it one of these keys cut and programmed are no good?
  4. Re: Key - need some good advice
    108 Post(s)
    1816 Post(s)
    The key is actually three separate functional components, the metal blade, the radio remote control and a inductively activated rolling code immobiliser chip. From VW you can order a full new key cut to the information held according to its VIN and this works as long as the car is original. This will operate the locks and nothing else. The remote control then has to be added to the central convivence system and this can be done using systems such as registered VCDS. The immobilser however is a different matter, the new chip in the key has to be added to the immobilser which is in the instrument panel and this requires security access to the unit which USED to be done using a one time only 7 digit "SKC" which was entered along with other date such as date and dealer number, this system has now been superseded and the programing is done on line to the VAG server in Germany and the operator sees nothing, you must have the VAG system ODIS with GEKO security access to do do this and some VAG independent specialists like myself have this access. There are other ways such as extracting the dash PIN and entering the data using other software and these are available from key specialists. A new key/chip section for a 2008 Touran from VW is £101.35 including VAT and comes cut to the cars VIN, the remote control is £104.38 and is not VIN specific.
  5. Re: Key - need some good advice
    Feb 2021
    If you live in the north east I’d recommend Newcastle car keys. A few years ago my dad took my only car keys with him on holiday by accident, Newcastle car keys drove to me in Teesside and cut me a new key for just over £100. It was just as good as the original and you couldn’t tell the difference. I’m guessing it would be cheaper if you have the original key.
  1. Unqualified mechanics advice - good or bad?
    By marc88 in forum Polo - Derby - Lupo - Fox
    Last Post: 25-05-2013, 10:12 AM
  2. Good morning and hello!.....and some advice on my b7 A4 1.9tdi
    By bigvinnie5737 in forum New Member Introductions
    Last Post: 11-06-2012, 10:34 AM
  3. Good advice for all partners
    By elvismiggell in forum Chat - Completely Off Topic
    Last Post: 31-10-2009, 07:25 AM
  4. Help Good Advice Needed!!!!!!!
    By philbee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-10-2007, 02:42 PM
  5. Help Needed...or good Advice!
    By yep.its.jay in forum Bora - 1998 - 2005
    Last Post: 01-07-2007, 04:20 PM
