Thread: Pre sense fault please contact workshop
  1. Pre sense fault please contact workshop
    Ireland
    I’m having the above fault on my S Line. I’ve cleaned the windscreen where the sensor is. The warning symbol on the dash occasionally goes away then reappears.
    Called Audi and they’ll have a look for a €150 diagnostic charge but anything after that they won’t speculate until they read the fault code.
    Just wondering if anyone has had the same fault and how did it end for you? I find pre sense completely useless by the way. In the 4 years I’ve had the car it’s been triggered about 5 times and never in a situation where I had been reckless or endangered myself or others.
    Could I be looking at an expensive repair here?
    Many thanks
  2. Re: Pre sense fault please contact workshop
    Feb 2012
    uk
    It's a guess, but I had the Yellow broken circle warning, Pre-sense disable etc etc....
    I cleaned the window by the camera, make sure you clean it good.
    Also check nothing has slipped down inside the glass and causing a shadow or obstruction.
    I don't know your version of car, mine has 360 cameras and auto park
    The system uses multiple sensors.
    Also Cleaning the front camera on mine (in the grill) stopped the problem. (tar spot).
    Audi pre sense 360˚
    The Audi pre sense 360˚ detects collision hazards all around the car and initiates specific safety measures. It includes the following driver assistant systems:
    • Audi pre sense front
    • Audi pre sense rear
    • Audi pre sense basic
    • Audi pre sense side
    Sensor areas of environment observation
    Hope it helps.
    2016 (B9) A4 Saloon S line 3.0 TDI quattro 272 PS tiptronic
    2012 (C7) A6 3.0 TDi Quattro S-Line, S-tronic, Sports Diff. 242PS
    2010 (C6) A6 3.0 TDi Quattro S-Line, Tiptronic, Le Mans. 233PS
  1. Replies: 6
    Last Post: 10-12-2021, 05:39 PM
  2. Please Help Ignition Lock Defective - contact workshop - no ignition, car is a brick
    By paceman in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-04-2019, 10:24 PM
  3. Steering lock fault : system fault! contact workshop.
    By DJS11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-12-2017, 11:20 PM
  4. Double Fault " Engine Fault - workshop & ESP Fault"
    By yusuf112 in forum Golf MK6 - 2009 - 2013
    Last Post: 10-02-2015, 10:23 AM
  5. Engine Workshop Fault!!!!!!!!!!!!!!
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-06-2010, 02:34 PM
