Thread: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
  1. Lightbulb Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Jan 2021
    Romania
    Hello! I've recently bought my A4 and it has a problem, coolant temp hardly reaches 700​C when I drive around for some time, and then when I stop for a few minutes, it goes down close to 500​. As I've read a lot around forums and Facebook groups, I've come to the conclusion that the problem might be in a second thermostat on a hose ( See nr. 23 in the photo below ). For my model, do you know what the code for that thermostat is? I need to order it because the service I went in can't seem to find it and basically said that they're gonna change it if and when I will manage to get one. I found this: 03L 122 157 M ( this is the hose from nr. 23 ), and I wanted to know if it work on my model, also, if it's possible to only change the thermostat and not the entire hose? I found this thermostat: 1K0 121 113A but I don't know if it's the right one. Sorry if I didn't explain it in the best way, english is not my first language, I just hope that people who had this problem on my model could help me!
  2. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Yes, 1K0 121 113A is the correct part.
    Available through Amazon or eBay & many parts distributors.
    It's easy enough to change yourself.
    You won't loose much coolant, but need to have a bottle to top up the reservoir afterwards.
  3. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Jan 2021
    Romania
    Quote Originally Posted by philipharmes View Post
    Hello! Thank you for the reply!
    Is this the right one?: https://www.autopieseonline24.ro/mahle-original/7815022
    If yes, I will order it right away!
  4. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Yes, correct one.
    Make sure you fit the same way as the one removed.
  5. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Jan 2021
    Romania
    Yes, correct one.
    Sorry for the late reply! I have ordered it, do you have any tutorial you could link me to?
  6. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Here is one from youtube, but in German I think.
    VW Passat - Motor wird nicht richtig warm 7B 3C Thermostat DSG defekt 2.0l TDI - YouTube
    Pictures speak a thousand words as they say.
    Don't know if it is the same engine layout as yours, but should be roughly in the same area.
  7. Re: Audi A4 B8 2009 2.0 TDI 170hp - Second thermostat problem ( coolant under 90° )
    Jan 2021
    Romania
    Okay, thank you!
  1. Audi A6 Coolant thermostat change
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-09-2016, 01:05 AM
  2. audi a3 2009 1.9tdi service light reset problem
    By chris96a4 in forum VCDS - Help Requests
    Last Post: 06-05-2014, 04:13 PM
  3. Thermostat & coolant change
    By stevepd in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-09-2013, 06:47 PM
  4. Please Help 2009 Audi A4 xenon headlight problem
    By dbonyad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-02-2013, 09:43 PM
  5. engine management light on - A3 2009 TDI 170HP
    By pform in forum 2.0TDi - Engine
    Last Post: 18-07-2010, 09:19 PM
