Thread: Broken rear coil spring Golf Mk6 GT TDI
  1. Broken rear coil spring Golf Mk6 GT TDI
    Jan 2010
    Bath
    Just discovered the knocking from the rear. Broken coil spring. I want to replace myself but having looked on Youtube, ******* shows that not only do I need to support and then remove the bolt connecting the control arm to the rear knuckle but I also need to loosen the arm bolted to the beam. It also seems that I need to mark the current position on the camber adjustment bolt. If I need to do all that then its beyond my capabilities working on my drive. If, however, its just a case of removing the bolt connecting the control arm to the rear knuckle then I can do it myself.
  2. Re: Broken rear coil spring Golf Mk6 GT TDI
    1836 Post(s)
    It is the toe adjustment bolt, not camber and it is extremely likely it will be seized solid and will have to be cut down both sides of the bush to get it out, then a new bush, bolt and alignment. This is why we use a special compressor that slots in there with the lower damper bolt out and it squeezes the spring together so you can take it out
    This was a rare one that came undone but the bush was FUBAR anyway.
  3. Re: Broken rear coil spring Golf Mk6 GT TDI
    Jan 2010
    Bath
    Many thanks Crasher. Glad I asked and you replied before I started the job. I'll get it done by an Independant garage.
  1. Rear coil spring broken on 1.8T Quattro
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-07-2015, 02:26 PM
  2. broken rear coil spring
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-02-2013, 10:41 AM
  3. N/s rear coil spring broken - should get tracking re-aligned
    By potshot in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-09-2012, 06:48 PM
  4. MOT fail - Rear coil spring broken
    By Sly in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-09-2011, 08:07 PM
  5. Broken Rear Coil Spring
    By peterb1 in forum Chat - Anything with wheels
    Last Post: 03-05-2008, 01:09 PM
