Thread: Creaky door hinge
  1. Creaky door hinge
    Jun 2020
    Nottingham
    Hello
    The drivers door on my 2014 Golf has recently been getting a bit creaky. It's also seemed to have frozen up when it's frosty as the door is hard to open, but ok once warmed up. It's also wet which I'm guessing isn't great.
    I was thinking I need to re lubricate it, but not sure what to use. Can anyone recommend the best lubricant to use on the door hinges please?
    Or if this is a common problem that needs a different fix?
    Cheers,
    Rich
  2. Re: Creaky door hinge
    Jul 2018
    Birmingham, West Midlands
    I’ve had success with using a penetrating lubricant / fluid on the hinges and working the door backwards and forwards on the Mk5...swing it open and closed between your hands.....try not to smash your fingers!
  3. Re: Creaky door hinge
    Jun 2020
    Nottingham
    Thanks, something like wd40? It has grease on it at the moment, would it matter that I'd be using something different?
  4. Re: Creaky door hinge
    Jul 2018
    There is probably factory used lubricant that has a VAG part number. Best to look up in the workshop manuals......
    I’ve just checked the Mk5 workshop manual and can’t see anything listed there.
    You will want something to penetrate the hinge / moving parts so guess any penetration fluid will work to be honest.
    Maybe grease after if you want to?
  5. Re: Creaky door hinge
    Leics
    I always use a light general purpose oil for door hinges and the like. 3 in One will do the job but I keep an oil can topped up with 5/30 oil whenever I have a drop left over from changing the engine oil. Doesn't need to be specific. Just remember to lubricate all hinges at least once a year.
  1. Please Help MK3 Door Hinge
    By tinnion in forum Golf MK3 - 1993 - 1999
    Last Post: 27-04-2009, 04:14 PM
  2. Please Help Door Hinge
    By nburgess in forum Golf MK4 - 1999 - 2004
    Last Post: 27-08-2008, 02:09 PM
  3. T5 Door Hinge
    By Dan T in forum The Commercial Range
    Last Post: 24-06-2008, 08:38 PM
  4. door hinge
    By 123singlemalt in forum Touran - Sharan - Caravelle
    Last Post: 17-12-2007, 03:56 PM
  5. creaky ns door on 2 door golf
    By stuffs in forum Golf MK4 - 1999 - 2004
    Last Post: 12-07-2007, 04:11 PM
