Thread: leaking wind screen washer bottle
  1. leaking wind screen washer bottle
    Dec 2018
    cardiff
    Bit misleading title as i know what the problem is
    basically was doing some cleaning of the inner arches and the wings, on the left side of the car the (lower) part
    of the washer bottle was blocking access to the front of the wing, so i removed it
    now i know the leak is where the (lower) bottle attaches to the upper, there is a sort of rubber/plastic (collar)
    unfortunately i unexpectedly needed to the the car the next day, so it got a little rushed putting it back together
    so before i take it all apart, id be interested to know it there is a specific way on how it should be done?
    only want to do this once, so any help advise welcome
  2. Re: leaking wind screen washer bottle
    Aug 2008
    West Yorkshire
    A quick fix, or permanent. I had the same issue. Pull the top part off and apply some sealant around the rubber seal area. Refit and allow to set. This should cure this leaking.
  3. Re: leaking wind screen washer bottle
    Dec 2018
    cardiff
    Thanks for the suggestion, id prefer a permanent fix
    i was thinking along the same lines but surely there is a way to do it right?
    i need to get this done over the next few days while ive got the time, so any advise welcome
  1. Leaking washer bottle connection
    By pbassred in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2020, 04:32 PM
  2. Leaking Windscreen Washer bottle
    By AndyN01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2020, 10:23 PM
  3. how to fix leaking washer bottle
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-05-2015, 02:55 PM
  4. Mk5 windscreen washer bottle...leaking
    By rush in forum Golf MK5 - 2004 - 2009
    Last Post: 26-05-2012, 11:04 AM
  5. Leaking Windscreen Washer Bottle
    By vwbolton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-01-2010, 06:32 PM
