Thread: broken fuel filter connector Help
  1. broken fuel filter connector Help
    Dec 2018
    cardiff
    Hi while changing the fuel filter on my S4, ive seemed to have broken one of the clips in the connector
    i looked at a few guides first and all seemed pretty straight forward, but having used a screwdriver on the connector
    pushed in (as done by others) ive chipped/broken the clip/connector
    so i put it back on and it is locked in place, but i obviously still want to change the filter
    so basically want to know the best course of action? id probably like to replace the connector as a whole
    but would need some advise on what i need and actually the best way to replace it (a link to the parts would be ideal)
    the clip thats broke/damaged is on the (out) line to the front of the car
    it seems the connectors are pushed into the tubing, but id be looking at a way of getting it a little hot
    to remove/replace the new connector
    obviously with the fuel and vapors in the area this is going to be difficult, anyone done this?
  2. Re: broken fuel filter connector Help
    1840 Post(s)
    Can we have a picture?
  3. Re: broken fuel filter connector Help
    Dec 2018
    cardiff
    currently the cars all back together including the under trays, so no pictures available
    from what ive looked into, there are two types of connector for the fuel lines
    the connectors i have, have a plastic (collar) inside that get pinched together (if you`ve got the proper tool)
    or the newer ones that are more like standard connectors, which can be pinched together with your fingers
  1. Should fuel filter/pollen filter be included as part of service?
    By jasonvaughan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-11-2018, 08:33 PM
  2. Question Electrical connector right near the end of the oil filter?
    By The Law in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2016, 07:26 PM
  3. Fuel Filter Connector
    By Rhys0_0 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-09-2012, 09:50 PM
  4. Please Help MK4 GOLF Alternator connector broken, unsure of wire order
    By SilverfoxUK in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2009, 08:04 PM
  5. Replacing A Broken Electrical Connector?
    By Nildefects in forum Audi A3 - Archive Topics
    Last Post: 25-07-2008, 12:18 PM
