Thread: Heater problems
Results 1 to 9 of 9
  1. Heater problems
    Jan 2021
    Newark, Notts
    Hello. I’ve got a A3 2.0 Quattro Diesel 15 plate 5 door. Major problems with heater. It blows out cold air. Coolant is topped up to right level, it’s been drained and flushed out and refilled. The silica bags in the coolant tank are still all fine and not burst. Waters passing through the matrix all good and seems to be no blockage. I’ve had it plugged into a diagnostic test, everything all good on there. I’m based in Nottinghamshire; any one ever had the same problem or similar? Where would be best to take it to around Lincoln, Nottingham, Sheffield or Doncaster? Thanks
  2. Re: Heater problems
    135 Post(s)
    2042 Post(s)
    This is now becoming a standard MQB platform annual issue, a quick look around the internet will find scores of people with Golf 7’s, A3 type 8P’s, Leon 5F, Octavia 5E etc etc with this problem, also some with overheating which could be connected. The European built cars use a Valeo heater matrix which was improved for the 2018 model year but I have no idea if it is better. There is no point trying to flush it, the design is top flow and designed not to burst so no amount of flushing or whatever you do will clear it. The silica cartridges in the coolant tank are there to try and make G13 coolant last longer but in 2017 the factory fill changed to G12 EVO we we have swapped over to using this.
  3. Re: Heater problems
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Crasher, a few questions:
    1. Does G12 Evo need to be changed after a certain number of years
    2. Do you remove the silica bag when replacing G13 with G12 Evo
    3. Our local TPS doesn't stock it. where should one buy it from.
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  4. Re: Heater problems
    135 Post(s)
    2042 Post(s)
    G12 Evo is the factory fill from 2017, from what I can find out it is a five year fill. The silica is in a tube, it is not this that causes the sludge, it is there to try and prevent it. Your TPS needs a kick up the ****.
  5. Re: Heater problems
    Aug 2007
    Hook Hampshire
    21 Post(s)
    No luck with TPS in Guildford or Reading. So I got a mail order delivery from Seat Motors Parts 4 x 5ltrs £73.64 (3.68/ltr) which is not a bad price considering the price of G13 from TPS.
  6. Re: Heater problems
    Mar 2016
    Minervois, France
    54 Post(s)
    Crasher, what is wrong with G13, please.
    I have been using it, or G13A, in all our cars since it was available, mixed 2:3 with demineralised water.
    I still have enough in stock to change the coolant from G12 in our T25.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  7. Re: Heater problems
    135 Post(s)
    2042 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    Therein lies the problem, G13 doesn't like tap water so now G12Evo is ready mixed.
  8. Re: Heater problems
    Aug 2007
    Hook Hampshire
    21 Post(s)
    So when switching to G12 evo, does one take the bag out of the expansion tank. This is for a 2011 A7 which has G12 originally but has been topped up with G13 over the years.
  9. Re: Heater problems
    Mar 2016
    Minervois, France
    54 Post(s)
    So there should be no problem if demineralised water is used?
    I refilled both the Alfa and the Audi with G13 mixture in 2016. I have not noticed any problems and the liquid is still clean and clear.
  1. Passat 2010 Heater Problems (with climate) & cutting out problems
    By asguk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-10-2015, 11:08 AM
  2. heater problems
    By Disk0 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-02-2014, 08:24 AM
  3. Heater problems
    By ju1es1970 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 02:51 PM
  4. Heater Problems
    By Tes.48 in forum A8 - S8 - V8
    Last Post: 17-01-2010, 11:01 PM
  5. Heater problems
    By Warehouse in forum Octavia
    Last Post: 21-11-2007, 10:24 PM
