Thread: 2013 Scirocco 2.0 TSI gear box oil change
Results 1 to 10 of 14
  1. 2013 Scirocco 2.0 TSI gear box oil change
    Oct 2010
    Malvern UK
    I have a 2013 Scirocco 2.0 TSI which I have had for a couple of months. Recently during the heavy rains I drove it inadvertently through some very deep water. The water came up above the headlights but somehow I managed to keep the car going through the flood and out the other side. I drove the car home (with no apparent problems) and left it overnight to drain and dry out. It started OK the next morning without any obvious issues. The only thing I have noticed is that the gear change now seems rougher than before the car had its bath!!! Is it possible that water got into the gearbox and if so how would I go about draining and refilling it? Quantities and specification of a suitable manual transmission oil would also be appreciated. Any other suggestions would be welcome.
  2. Re: 2013 Scirocco 2.0 TSI gear box oil change
    May 2012
    Everywhere
    308 Post(s)
    TFSI !!
    2.3 L
  3. Re: 2013 Scirocco 2.0 TSI gear box oil change
    1840 Post(s)
    I have just rebuilt my 02M box and yes it would be possible for water to get into the box through the breather but it would be a tiny amount as it is designed to close with external pressure so I would say it is more likely the water has affected the cable shift system. I used Red Line MTL
  4. Re: 2013 Scirocco 2.0 TSI gear box oil change
    May 2012
    Everywhere
    308 Post(s)
    Incorrect spec oil it requires a 70W75 not a 75W80 .
    There are no VAG specs whatsoever with this Red Line , whereas the Millers & Fuchs , carry G 052 171 , 178 , 512 etc .
    The Red Line is simply too thick as the viscosity units reveal !
    Fuchs Titan Sintofluid FE SAE 75W
    40° C & 100°C
    40.8 & 6.7 cSt
    Millers TRX Synth 75W
    28.1 & 6.1 cSt
    Red Line MTL
    50.8 & 10.4 cSt
    I would go with the thinnest as it will be the most slick when cold.
  5. Re: 2013 Scirocco 2.0 TSI gear box oil change
    1840 Post(s)
    I have had spectacular results with it in VAG gearbox’s for around 25 years.
    Opinion also seems to vary on what G 052 527 A2 is.
  6. Re: 2013 Scirocco 2.0 TSI gear box oil change
    1840 Post(s)
    I don’t know who closed this.
  7. Re: 2013 Scirocco 2.0 TSI gear box oil change
    May 2006
    Redruth, United Kingdom
    Quote Originally Posted by Gazwould View Post
    TFSI !!
    2.3 L
    You can get these from us with VWAUDIFORUM discount 75w Fully Synthetic Gearbox Oil For Manual Gearboxes
    Cheers,
    Guy
  8. Re: 2013 Scirocco 2.0 TSI gear box oil change
    May 2012
    Everywhere
    308 Post(s)
    I rest my case...
  9. Re: 2013 Scirocco 2.0 TSI gear box oil change
    May 2012
    Everywhere
    308 Post(s)
    40° C & 100°C
    40.8 & 6.7 cSt
    28.1 & 6.1 cSt
    Red Line MTL
    50.8 & 10.4 cSt
    One for Stevie .
    Red Line MT-LV
    comparable to the Fuchs Titan Sintofluid FE SAE 75W and Millers TRX Synth 75W .
    Red Line MT-LV
    29.8 & 6.5 cSt .
    RED LINE MT-LV HIGH-PERFORMANCE GEAR OIL is a full-synthetic ester-based lubricant designed for use in manual transmissions and front-wheel-drive transaxles. This shear-stable formula resists breakdown for extended periods and offers more consistent viscosity in warm and cold temperatures for less gear noise and improved shifting. This fluid is less slippery for improved synchronizer coefficient of friction and offers stronger film strength for better wear protection.
    Suitable replacement for:
    API GL-4 / GL-3 / GL-1
    SAE 70W/75W
    BMW DTF 1
    BMW X-Drive Transfer Case Fluid
    BMW 83 22 0 306 816
    BMW 83 22 0 397 244
    BMW 83 22 2 409 710
    Cadillac 19331044
    Castrol BOT 270A - Graziano Transaxle for Aston Martin, Audi and Lamborghini
    Castrol BOT 350 M3
    Castrol BOT 303 mod
    Chevron GS CALTEX MTF HD 70W
    Chrysler/Dodge/Jeep 9.55550-MZ6
    Dodge/Fiat 68092630AA
    Ford XT-11-QDC
    Ford WSS-M2C200-D2
    GM 10-4037
    GM 19259104
    GM 19259105
    Honda i-Shift MTF-3
    Honda i-Shift MTF-III
    Hyundai/Kia 00232-19063
    Jaguar/Land Rover C2Z25586
    MB A001 989 98 03 09
    MB 235.10
    MB 235.73
    MB 317
    MB 001 989 26 03 10
    MB A 001 989 98 03 09
    Nissan/Infinity 999MP-TF0870P
    Nissan/Infinity TF0870
    Porsche 000 043 300 36
    Porsche 000 043 301 36
    Porsche 000 043 305 63
    Shell SPIRAX S6 GHME 70W
    Shell TF 0870
    SK HK MTF 70W
    Toyota MT Gear Oil LV 75W
    Toyota 08885-81040
    Toyota/Lexus transfer case fluid "Genuine Gear Oil LF 75W“ 08885-81080
    Toyota/Scion Manual Transmission Oil LV
    Toyota/Scion 08885-81001
    VW G 052 726
    VW/Audi G 052 171
    VW/Audi G 052 512 A2
    VW/Audi G 055 515
    VW/Audi G 052 527 A2
    VW/Audi G 052 725
    VW/Audi G 060 726 A2
    VW/Audi G 070 726 A2
    Only problem is cost , going by the L or near L Quart , Fuchs is £13 , Millers £15 and Red Line £20 .
  10. Re: 2013 Scirocco 2.0 TSI gear box oil change
    1840 Post(s)
    That is news, like when I discovered G12 Evo coolant a few weeks back, a bit slow on the uptake... I blame my age. When we started this debate I went onto their web site and didn’t notice this. I will order some with my next order and try it as now I have the car back on the road I have noticed a very slight balk into second when very cold. I just noticed an odd forum action which explains why it must have been me who closed this thread; as an admin, you tap post quick reply just off the edge it also ticks close thread, I will have to tell Stu.
  1. How To dsg gear knob VW SCIROCCO
    By leavr6 in forum Scirocco - 2008-
    Last Post: 06-02-2020, 12:31 PM
  2. How To dsg gear knob VW SCIROCCO
    By leavr6 in forum New Member Introductions
    Last Post: 02-02-2020, 02:05 PM
  3. Question 2013 B8 Cam Belt Change
    By pbrazendale in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-04-2017, 08:56 AM
  4. How To Hi how can I change DRLs to fog lights on a vw polo 2013 6r
    By Ahdil123 in forum VCDS - Help Requests
    Last Post: 15-03-2015, 03:44 PM
  5. Scirocco on 5th Gear
    By iroc in forum Scirocco - 2008-
    Last Post: 19-09-2008, 10:02 PM
