Thread: What is the location of the oil filter in a S3 2011
  1. What is the location of the oil filter in a S3 2011
    London
    I plan to change the oil in an elderly relative's 2011 S3 next month, when they visit me.
    If it makes any difference, VCDS tells me the chassis type is 8P-AU35 (8P0), the engine is 2.0L petrol.
  2. Re: What is the location of the oil filter in a S3 2011
    1840 Post(s)
    It is accessed from under the car, a paper element in a plastic hosing which likes to crack, element 06D 115 562 containing O ring 06D 115 475, £14.50 genuine. There is a drain bung in the middle which you are supposed to use with a special drain tube to stop the oil going all over when you take the housing off. From memory it is a 36mm hex socket you need.
  3. Re: What is the location of the oil filter in a S3 2011
    London
    Thank you, much appreciated.
  1. q7 2011 3.0 tdi s line crank case breather location
    By gcq7 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 18-10-2017, 09:13 PM
  2. A6 C7 2011 2.0 tdiAircon drain location
    By ollysteve in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-04-2017, 11:10 AM
  3. Question 2011 CC Alarm Horn Location
    By johnnypbristol in forum Passat CC
    Last Post: 06-03-2017, 06:12 PM
  4. A4 Oil Filter Location
    By brad.mcbride in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-07-2008, 03:36 AM
  5. Oil filter location
    By dfb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-06-2007, 10:05 PM
