Hi my passat which is a 57 plate but has lots of parts for a 58 plate has a problem with the front drivers door not opening from the outside
I've been trying to do this for months now
The door has been stripped down to everything apart from the window regulator
Ive got a secondhand carrier with same code after getting two with wrong code
Still makes no difference
The door works a few times then locks up from outside any ideas I've got a new cable which seems a few mill. Shorter would that work
Best wishes keep safe sidepike
