Hi All,
When I insert the ignition key I get no ignition lights, no sound of the steering unlocking and the steering lock is off all the time.
My mechanic suggested that the likely cause is that the steering lock is seized or the module/motor has a fault.
I decided to remove it so I can test the motor, switches etc, however despite removing the security bolts (Column is still in the car) I cannot remove the acutator but it is loose.
Have I missed an additional fixing or clip of some kind?
Any help appreciated :-)
Regards
Chris
