Hello again,
more questions about the audi I bught at auction a while back, I have noticed that there are no engine management or traction control warning lights on start up.There is however an audible bleep on start up which tells me that something is not right.
To cut a long story short it turns out that the car had a brake pedal sensor fault on diagnosis, have changed abs pump with matching numbers but bleep is still there and now I`m wondering whether bleep is down to no lights.
Its obvoius that someone has taken them out or something as my mechanic managed to light up all dash with his diagnostics but still no lights for engine management or traction control.
My question is can lights be repaired or do I need to get a set of new clocks as my rev counter is not working either and if so do do the numbers have to match exactly.
I have been told that I need clocks with the following numbers 8PO 920951 E
once again , my thanks in advance for any replies
