Thread: Anyone with VagCom to offer any help.
  1. Anyone with VagCom to offer any help.
    Jul 2009
    uk
    Hi my son's A6 C6 Avant is need of someone's help with VCDS in the Newport area.
    It is draining it battery sharply from a full charge, if battery is disconnected it holds its charge
    2010 A6 C6-Avant 2.7 TDi LeMans (FaceLift)
  2. Re: Anyone with VagCom to offer any help.
    1840 Post(s)
    Usually it is the electronics box full of water.
  3. Re: Anyone with VagCom to offer any help.
    Jul 2009
    uk
    Thanks,
    Which one are you reffering to ?
  4. Re: Anyone with VagCom to offer any help.
    1840 Post(s)
    The most common issue is the plenum chamber overflowing into the electronics but a new one I have come across is the parking brake control unit getting wet in the right corner of the boot and keeping the system awake. The key to look out for is the parking brake switch and dash warning light staying on for more than a few minutes and also randomly blinking. If the sound deadening under the ECU is wet and the box has corrosion stains around the plug it needs to be replaced and the leak (usually the light unit) dealt with and replacing the ECU is a complex process that so far I can only do using the VAG system ODIS as the new box is refused by the car until the cars build data held in Germany is updated.
  1. Got an offer
    By Chris Meyer in forum 80 - 90
    Last Post: 01-06-2016, 12:04 PM
  2. Oil on Offer
    By Peter D in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2013, 09:16 PM
  3. Re-Map offer
    By as-tuning in forum Audi A3 - Archive Topics
    Last Post: 26-07-2008, 12:46 PM
