Thread: Load cover not lifting on avant.
  1. Load cover not lifting on avant.
    Hi all,
    My load cover is stopped lifting when I open the boot. It moves up slight to the position in picture but then stops. Any ideas?
    Not sure if related but I did remove the cover revetly and pit back in, however cannot see this would affect it?
  2. Re: Load cover not lifting on avant.
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Have you scanned it? Mine did this a few months ago, started working a week later, when i scanned it it said it had lost its basic settings.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Load cover not lifting on avant.
    No not yet as not got scanner. Did you just reset it and started working?
  4. Re: Load cover not lifting on avant.
    Dec 2007
    43 Post(s)
    Quote Originally Posted by Rhys View Post
    I did nothing at all it just worked again on its own.
  5. Re: Load cover not lifting on avant.
    May 2013
    Quote Originally Posted by dean warren View Post
    I had that problem, under warranty Audi replaced the cable and motor, possibly it came as a complete part.
    The motor seemed to work ok, the problem I reported was the broken plastic clip which kept falling out.
    Just maybe the broken clip was a symptom and the cause being the motor failing?! Whatever, I’ve not had the problem since.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  6. Re: Load cover not lifting on avant.
    Got it scanned and says lost basic settings. Tried to reset with scanner and not fixing. When tested i got it to go all the way up, however seems slow when going past middle section. After two goes of working its stopped again... ugh.
    Razor I did have a clip snap off too!! Didn't think anything of it and put back in. Hmm might be something with motor possibly struggling?
    Might pop to local mechanic to have a look at.
  1. Avant powered load cover
    By colinrm in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-12-2017, 09:58 PM
  2. A6 Avant C5 2002 Load Cover
    By chalkie1269 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-01-2015, 06:34 PM
  3. Question A4 Avant B6 - Load Cover
    By seanxb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-07-2010, 04:37 PM
  4. A4 Avant B6 Load Cover
    By stinkerpuffit in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-11-2009, 11:03 PM
  5. Question Avant B8 Load Bay Cover
    By timpe in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-03-2009, 07:16 PM
