Thread: Locked out!!
  1. Locked out!!
    Dec 2020
    UK Shrewsbury
    Just been locked out of my B6 estate. The key fob is in the ignition with the engine running.. But the central locking seems to have been in lock mode when I shut the door. The bonnet was open , so I've turned off the engine by removing a 50A fuse. Does anyone know if I can control the central locking through the engine bay somehow?
  2. Re: Locked out!!
    1837 Post(s)
    In that situation (as I was twice not long back) I called out a car lock company and they used a device to pick the lock, on a T5 it took the chap about 30 seconds. It happens when the convenience system does not see the ignition is on and on the T5 it was the ignition switch.
  3. Re: Locked out!!
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by marksmith89@yah View Post
    Apparently the plastic emergency keys are only cut with a few variations. I can open one or two other 2007 passat front doors in my area with my emergency key, fortunately both are friends.
  4. Re: Locked out!!
    Dec 2020
    UK Shrewsbury
    I just thought there may have been a way of manipulating the locking from the engine bay. Anyway, I borrowed a friends breaking-in kit (bladder and wire). I was lucky the ignition was still on so it was easy to tap the window buttons...
  1. Locked ECU?
    By alexhill7 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2012, 09:40 AM
  2. locked in
    By kamo44 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2009, 05:35 PM
  3. Locked ECM ?
    By nego_metuere in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2008, 03:14 AM
  4. Locked Out!
    By exedriver in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2008, 02:06 PM
  5. Locked out!
    By pkataky in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-01-2008, 09:21 PM
