Thread: gearbox malfunction a6 c7 allroad 2012
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: gearbox malfunction a6 c7 allroad 2012
    #11
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by Elansear View Post
    Hi as has been mentioned by others it sounds like a wire loom problem, perhaps as you mentioned heavy rain, water ingress in a connector possibly under the car. As you are going to have to wait might be worth getting a big can of WD40 and give any accessible connections a good spray, you have nothing to loose perhaps worth trying to get a cheap hand scanner to assist in seeing if that helps. Good luck.
    hi cheers i might give that a try ...if it ever stops raining here
  2. Re: gearbox malfunction a6 c7 allroad 2012
    #12
    May 2008
    40 Post(s)
    Check all the pine are still in the back of the OBD socket, seen a few with the odd pin pushed out thus losing comms with some ecus.
    I have seen it on several trucks, not had much to do with car repairs beyond my own, plues as its my won I am careful with the test kit.
  3. Re: gearbox malfunction a6 c7 allroad 2012
    #13
    Jun 2012
    whitland uk
    7 Post(s)
    still no luck i have had a vag trained mechanic plugged it in to his diagnostics it and it seems to be definitely a wiring issue,i have never seen so much wiring on a car .he has unplugged loads of connections but as yet we can not locate fault . he is coming back to have another go later this week .there is no communication between electonics
  4. Re: gearbox malfunction a6 c7 allroad 2012
    #14
    Enfield, North London
    7 Post(s)
    Quote Originally Posted by chris.d View Post
    as they do have a audi trained mechanic who does the Audi repairs at a reasonable rate
    Ideally one wants a really expensive mechanic who has been there, done that and got dozens of T-shirts!
    Audi A6 Avant BiTDi C7 SE 2014
    John
    (The Beemer is a bike)
  5. Re: gearbox malfunction a6 c7 allroad 2012
    #15
    Jan 2009
    Birmingham
    35 Post(s)
    check passenger floor carpet is it wet?
  6. Re: gearbox malfunction a6 c7 allroad 2012
    #16
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by arman123 View Post
    hi
    no all floor footwells are dry ,no sign of water any where in the car.
  7. Re: gearbox malfunction a6 c7 allroad 2012
    #17
    Jun 2012
    whitland uk
    7 Post(s)
    hi all
    just to update on this .i tried everything i could .but eventually gave up and recovered car to audi dealership
    after 5 hours of testing ...
    it turned out to bej33 gateway control unit
    just drove car home, good to have it back,i missed it
  8. Re: gearbox malfunction a6 c7 allroad 2012
    #18
    Co Durham
    You were lucky there! I had a similiar problem, car recovered to an Audi dealer, turned out it was a mechatronic unit failure in the S=Tronic box. A coolant valve (N82) that opens and closes to allow a flow of coolant around the gearbox as required, was leaking. Fluid runs up a cable through the connection into the Mechatronic unit. I think there had been some problems for a few weeks as I occasionally had the feeling that reverse gear was either not engaging properly or not very sensitive in operation. Maybe its the shock of a plus £4k repair bill. but it does seem smoother in operation now.
  1. Gearbox malfunction
    By Dazlav@aol.com in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 13-04-2021, 01:46 PM
  2. Audi A4 automatic 2014 Gearbox malfunction
    By moo_s in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 03-06-2020, 08:01 PM
  3. Audi A6 2012 - Gearbox Malfunction: you can continue driving
    By Audia63.0 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-11-2017, 11:29 AM
  4. Question Gearbox Malfunction
    By JayNana in forum A7 - S7
    Last Post: 23-03-2017, 04:58 PM
  5. Replies: 2
    Last Post: 12-08-2016, 07:35 PM
