Thread: gearbox malfunction a6 c7 allroad 2012
Results 1 to 10 of 18
  1. gearbox malfunction a6 c7 allroad 2012
    Jun 2012
    whitland uk
    7 Post(s)
    hi all,i am in need of some help here.
    just went to start the car and get message gearbox malfunction, tried to start the car ,turns over and sometimes stars for a couple seconds and dies ,and getting messages on dash for lots of faults now h,brake lights and so on ,checked under scuttle panel for water (as i think that is where ecu is on the drivers side )but none .., last time i drove the car all was fine but it was chucking down rain heavy though !! .
    any ideas ??????????????
  2. Re: gearbox malfunction a6 c7 allroad 2012
    Southern County Softy
    20 Post(s)
    Sounds like a low battery to me.
    Engine starting and cutting out could be the immobiliser.
    Sent from my SM-G960F using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: gearbox malfunction a6 c7 allroad 2012
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by kite View Post
    hi thanks for your thoughts , but it is turning over quite strong and i did not have any low battery warning recently
  4. Re: gearbox malfunction a6 c7 allroad 2012
    Enfield, North London
    7 Post(s)
    It's likely a poor connection, but you will need to get the car scanned to find out the location.
    15 years ago I remember a gearbox going into limp mode because a cable on the brake pedal had become disconnected. The problem was only diagnosed after 2 gearbox rebuilds!
    Audi A6 Avant BiTDi C7 SE 2014
    John
    (The Beemer is a bike)
    0 2 0
  5. Re: gearbox malfunction a6 c7 allroad 2012
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by beemerboy9 View Post
    hi thanks for that hope you are right .i have rac coming in the morning so i get diagnostic free .
  6. Re: gearbox malfunction a6 c7 allroad 2012
    Jul 2010
    lichfield uk
    I would check gearbox cable connection
  7. Re: gearbox malfunction a6 c7 allroad 2012
    Jun 2012
    whitland uk
    7 Post(s)
    ok. rac man been here for an hour did a reset of all the faults .then his diagnostics states no communication between gearbox brakes.steering etc
    so looks like i have to get it to a garage but local one is shut until jan 4th so will have to wait until they re open .as they do have a audi trained mechanic who does the audi repairs at a reasonable rate
  8. Re: gearbox malfunction a6 c7 allroad 2012
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Have you checked all the fuses in the engine bay, at the ends of the dash & in the boot ?
    One large fuse may provide power for several electronic modules.
  9. Re: gearbox malfunction a6 c7 allroad 2012
    Jun 2012
    whitland uk
    7 Post(s)
    Quote Originally Posted by philipharmes View Post
    hi yes rac man went through the fuses
  10. Re: gearbox malfunction a6 c7 allroad 2012
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi as has been mentioned by others it sounds like a wire loom problem, perhaps as you mentioned heavy rain, water ingress in a connector possibly under the car. As you are going to have to wait might be worth getting a big can of WD40 and give any accessible connections a good spray, you have nothing to loose perhaps worth trying to get a cheap hand scanner to assist in seeing if that helps. Good luck.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Gearbox malfunction
    By Dazlav@aol.com in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 13-04-2021, 01:46 PM
  2. Audi A4 automatic 2014 Gearbox malfunction
    By moo_s in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 03-06-2020, 08:01 PM
  3. Audi A6 2012 - Gearbox Malfunction: you can continue driving
    By Audia63.0 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-11-2017, 11:29 AM
  4. Question Gearbox Malfunction
    By JayNana in forum A7 - S7
    Last Post: 23-03-2017, 04:58 PM
  5. Replies: 2
    Last Post: 12-08-2016, 07:35 PM
