Thread: Engine Mgt Light ON but no errors in VCDS - Help
  1. Engine Mgt Light ON but no errors in VCDS - Help
    Nov 2018
    Tamworth
    22 Post(s)
    Hi all,
    2014 Seat Leon with 1.6 diesel J623-CLHA 95K miles.
    Rather confused as the Engine light has come on but there's no errors as such in VCDS (see later).
    The "auto scan" brought up a glow plug issue and a Neutral Gear sensor.
    My first thought was maybe a DPF issue but the ash volume and soot levels don't look too bad?
    I cleared alll the DTC's which extinguished the MIL
    The thing that caught my eye was this:
    VIN: VSSZZZ5FZER081161 License Plate: KV14 FFE
    Address 01: Engine (04L 906 021 M)
    17:28:48
    IDE00433 Particle filter: oil ash volume 0.08 l
    IDE00434 Particle filter: soot mass calculated 21.10 g
    IDE00435 Particle filter: soot mass measured 4.89 g
    Readiness Status: 00000000 00001110 11101000 11101000
    MIL Status: MIL OFF
    Comprehensive Components: Passed
    Fuel System: Passed
    Exhaust Gas Recirculation: Failed or Incomplete
    Number of EOBD-related DTC(s): 0
    Is this pointing to the dreaded EGR valve being duff?
    Or something else?
    Thanks in advance.
    Andy.
  2. Re: Engine Mgt Light ON but no errors in VCDS - Help
    1841 Post(s)
    The loading in the DPF is too high, give it a forced regen
  3. Re: Engine Mgt Light ON but no errors in VCDS - Help
    Nov 2018
    Tamworth
    22 Post(s)
    Crasher, you're a star .
    After a regen with VCDS it looks like this:
    11:15:32
    IDE00432 Particle filter: time since last regeneration 7092 s
    IDE00434 Particle filter: soot mass calculated 1.51 g
    IDE00435 Particle filter: soot mass measured -9.08 g
    IDE00436 Particle filter: kilometers since last regeneration 57361 m (don't understand this one as she hadn't moved??)
    And the engine light has gone out.
    Sorry for not doing my homework properly and finding out that the original figures were too high
    All the best.
    Andy.
  4. Re: Engine Mgt Light ON but no errors in VCDS - Help
    1841 Post(s)
    Excellent.
  5. Re: Engine Mgt Light ON but no errors in VCDS - Help
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " MIL Status: MIL OFF
    Fuel System: Passed
    EGR valve
    being duff? "
    Keep an eye on that EGR.
    If it's sticking open the DPF will fill with soot much quicker than normal & will work against the DPF regenerating.
  6. Re: Engine Mgt Light ON but no errors in VCDS - Help
    1841 Post(s)
    Possibly, we are just doing one at the moment, horrid job.
  7. Re: Engine Mgt Light ON but no errors in VCDS - Help
    Nov 2018
    Tamworth
    22 Post(s)
    Quote Originally Posted by philipharmes View Post
    Fuel System: Passed
    EGR valve
    being duff? "
    Thanks for that.
    It's my son's car but sounds like it might be worth serious consideration of what to replace it with.
    Andy.
  1. Engine management light and glow plug light errors/fault codes
    By zhussain087 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-06-2020, 03:32 PM
  2. Audi Q7 VCDS errors
    By creatorul in forum VCDS - Help Requests
    Last Post: 22-01-2016, 10:11 PM
  3. Help Please! VCDS Error codes - Fuel Trim and Lambda errors
    By Tecnic91687 in forum VCDS - Help Requests
    Last Post: 18-08-2014, 07:55 PM
  4. VCDS Lite Communication Errors.
    By Frosty90 in forum VCDS - General Questions
    Last Post: 05-06-2014, 04:57 PM
  5. Please Help Two questions - hl brake light & side light errors
    By rosso rocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-07-2013, 05:27 PM
